Thread: First above ground pool. Pointers?
    May 2015
    Walterboro
    1
    I am about to install my first above ground pool. I ordered a 15'x30'x52" saltwater pool (not sure why it is called saltwater pool, didn't come with a salt water generator). I'm almost finished with the ground prep now. Any advice on installing the pool would be greatly appreciated! I plan on doing the foam on the floor, cove, and walls. Also should I go with a saltwater generator or chlorine?
    Casey's Avatar
    SW PA
    10,457
    Re: First above ground pool. Pointers?
    SWG and chlorine are essentially the same. The SWG will cost more up front and if you go with chlorine, we highly recommend liquid chlorine bleach from the grocery aisle. That means you'll be lugging bottles to the pool. So, which would you rather do?
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Also do you want to add chlorine every day? That was the deciding factor for me on adding a SWG. I like automation. It is not set it and forget it though. You still have to test often to make sure it is doing what it is suppose to. Also pH needs to be lowered a little more often with a SWG.
    Just to check, have you been all the way through Pool School?
    Do you have one of the Recommended Test Kits?
    If not, seriously, you are setting yourself up for failure.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Aug 2011
    Augusta, Kansas
    88
    Order your test kit today. I swear by the TF-100 and the Aqua Check (salt) test strips - it is worth EVERY PENNY. I have a SWG and for our lifestyle (work, ball games 2-3 nights a week, etc) it is the only way to go as I don't have the time to test and add bleach every night. We start the season by filling the pool (from the winter lowered) test, vacuum, add the appropriate amount of salt (use the cheapest from WalMart SALT is SALT - pool or water softener as long as it is 100% salt you are good), get CYA level good, and add bleach during startup. During that opening time I'm adding bleach as the SWG keeps you level but you shouldn't use it to bring up your chlorine level when bleach can do it super quick and easy.
    Once you are balanced then kick on the generator and you are done! Oh I don't add much of anything else the rest of the summer. I test to be sure and do spend time having to keep the PH down as it goes up but cost wise you aren't looking at much pool chemical wise....pool toys are another matter as I'm a sucker for another cool float.
    This summer's opening cost
    4 bottles 12% bleach - $7.99 (caught a sale)
    4 bags of salt - $20
    Stabilizer/CYA - $15
    Done!
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    Agreed! I easily run my pool all summer for less than $100 in supplies.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
