Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Please take a look and tell me what you think. Help opening my pool...
    Jun 2015
    Ardmore, OK.
    14
    I have been lurking and learning in the TFP forum for about 3 years now, and using the BBB method for two years with great results! Thank you.
    Unfortunately this year has been different. My cover had a rip in it so my pool got swampy. I netted the pool out and vacuumed all that I could and got started SLAMMING. I slammed for about 8 days straight with only minor improvements each day. The day before yesterday I could finally see a big difference. My water was almost clear, I could see the bottom, and boy was I happy.
    Yesterday I woke up to a green pool again. The only thing different that I did was back wash my sand filter as the pressure was getting high. All day yesterday, all night, and all day today I shocked my pool at mustard algae level to no avail.
    I will tell you what I have done since, and hopefully you can follow along with any help, as I have now spent a small fortune on liquid bleach and still have a green pool.
    10,400 Gallon above ground pool
    Sand filter with 1 year old sand
    I did a deep sand cleaning before starting this year.
    Also, just today I added 1.5 cups of DE to my sand filter, that raised my pressure from 15.5 psi to 16.5 psi. I have never used DE but am going to give it a shot.
    6/9/2015 at 7:45 PM
    FC 2.0
    CC <0.5
    PH 7.2
    TA 110
    CH 70
    CYA <30
    As the CYA is low I added enough powdered CYA to raise it up 15ppm.
    I did the testing and it seems that the CYA is just barely under 30 so I have been shocking at 12ppm chlorine.
    I added 162oz. of 8.25% liquid chlorine to raise it to 12.
    Anyone have suggestions?
    Jun 2015
    Ardmore, OK.
    14
    Re: Please take a look and tell me what you think. Help opening my pool...
    6/9/2015 9:00 PM After the sun has went down.
    12 ppm FC
    <0.5 CC
    10,400 Gallon Circular Above Ground Pool
    Hayward Power-Flo LX Pump 1.5 HP
    Dream Line High Rate Sand Filter
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 12:15 AM
    FC 11
    I added 16oz of 8% liquid bleach to get back to 12.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    With your 1 ppm loss by midnight it certainly sounds like you still have something trying to grow in there, keep the SLAM up and let us know how things progress.
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 3:30 AM
    FC 12
    No action taken.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    hey Jesse, the reason your pool went green again is your fc droped below 12 ( you said 2), any time it drops below 12 they will start growing again... your almost there just keep that fc up, take it to mustard shock level at night or when you are not there to check..
    Also, you are very dedicated waking up at 330 in the morning
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Good morning. When did you add the CYA? It takes a good week to show up on tests.
    Maybe you ave a bit more CYA than you think...in which case, you might not be at "kill zone" most of the time at 12.
    Why not bring it up to mustard shock level for 30 ppm CYA of 19 and ride it there for a day, not letting it drop below 16 (which is target Slam for 40 ppm cya...just in case you have more than you think) and see if the color starts to change.
    As long as you stay a bit under mustard shock level, you won't harm the liner.
    Also remember that every minute you're BELOW your target, you're letting algae outpace you. Stay on top of it as much as you can and report back if that made a difference.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 5:45 AM
    FC 11
    Added 16oz chlorine
    I appreciate the help. I work nights so being up at 3 is no big deal. Ask me to get up at 10 am and that's another story.
    Jun 2015
    Ardmore, OK.
    14
    I tested CYA yesterday, it was below 30. Yesterday I added enough to raise it 15ppm per the instructions. I will raise it up to 19 and see what happens.
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 6:00 AM
    I added 113 oz Chlorine
    This should take it to 19.
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 10:15 AM
    FC 15
    I added 65 oz chlorine
    Jul 2013
    Fletcher, OK
    3,353
    awesome, keep it there and soon you will be done
    reagan's Avatar
    May 2011
    NE Ohio
    64
    Go, Jesse, Go! Go, Jesse, Go! (Where is the cheerleader-with-pompoms smilie when you need it?)
    BBB/TFP/Taylor K-2006 Evangelist!
    6/13 - Installed AG Sharkline Heritage 21'x54" 11K gallons. Hayward 1660s sand filter, Hayward single-speed 1 hp pump; city water. Husband builds, I maintain.
    5/11 - Starter pool 6000-gallon Intex Ultra 16'x48" AG with standard 1500 gph 1/3 hp cartridge filter.
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 3:15 PM
    FC 11
    I added 129 oz chlorine
    I can see the bottom again! It is starting to clear up slowly.
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by reagan View Post
    Jun 2015
    Ardmore, OK.
    14
    6/10/2015 8:15 PM
    FC 13
    I added 97 oz chlorine
    Its still not clear, but it is clearing up.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Glad you're making process. Things will start to get easier real soon if you keep hitting 'er hard, promise
    Helpful Links:
    Jun 2015
    Ardmore, OK.
    14
    Well....the pool is looking decent. The only problem I have now is I ran out of reagent R-0871 for my FAS-DPD test. My plan was to hit the pool store first thing this morning to restock. Unfortunately none of my local stores have it in stock. I ordered it and it will be here tomorrow morning.
    My plan is to add the same amount of liquid chlorine that I did yesterday at the same times.
    I realize this could over chlorinate, but I think I would rather do that than take the chance of it being under chlorinated and turn back swampy.
    Does anyone see a problem with this plan?
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by Jesse_224 View Post
    that's what I would do. you should have a pretty good idea of the FC loss and how much you have been adding. it should increase the demand since its getting better each day. keep at it, and then confirm when you get more reagent.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
  20. Back To Top    #20
    Jun 2015
    Ardmore, OK.
    14
    Back in business! After vacuuming and backwashing today here is where I was at..
    6/12/15 5:30 PM
    FC 10
    I added 146 oz liquid chlorine
    I also added 1/2 C. DE to the sand filter - I had 1 1/2 C. in the last few days but I didn't like how much it reduced my return.
    I can see the light at the end of the tunnel!
