Results 1 to 12 of 12
Thread: Need a salt test?
    May 2015
    Forney, TX
    14
    Need a salt test?
    We have an aqualogic P4 that shows us the salt level (granted it might take a couple of hours for the salt level to update) should we still get a salt tester kit?
    38'x17.5' 19k IG pebble, Hayward ProLogic P4 w/ T-15 SWG, DE(now Fiber) Hayward DE6020 filter, Hayward Northstar 2HP single speed pump, Pump(Advantage CK256C-075-P) for Hayward Cleaner (Hayward Viio Turbo model 5500), Built 2008, City water fill, TF100 Kit + Salt test kit w/speedstir
    38,275
    Re: Need a salt test?
    Welcome to TFP!!!
    I split your post to its own thread, not polite to hijack
    I would get a salt test because the SWG can start to give false readings if things go south.
    May 2015
    Forney, TX
    14
    Thank you for splitting it off.
    I would recommend the k-1766. Especially with the Aquarite, the salt level as tested vs the box reading can tell you when your cell begins to fail.
    Support the site
    May 2015
    TX
    8
    I would get an electronic salt tester. I just did so after a recommendation from a pool guy (that did our pool inspection). They run $100 or so from Amazon. I got the ExTech ExStik II. Tests salt, TDS, and temp.
    I found my SWG was off by several hundred ppm after getting the tester. You can also buy a calibration solution for $10-15 (for a lifetime supply) and calibrate your tester every 6 months.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Quote Originally Posted by Ausmatt View Post
    Waste of money if you ask me... It was off by a few hundred compared to the Taylor test??? Or compared to test strips? I doubt it was Taylor.
    Regardless, a few hundred ppm is not enough to worry about. Salt does not need to be exact.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    May 2015
    TX
    8
    Compared to the SWG sensor. Regarding a Taylor test or an electronic tester, I believe the payback period is about 1 year if you test salt and TDS 1-2x/week. (~20 tests per bottle). So for me, it's a good investment and a heck of a lot quicker than a chemical test.
    But either one is sufficient. My main point was to not rely on the SWG sensor.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's a personal choice if you ask me. If you feel a good TDS meter is worth it over testing with Silver Nitrate, then by all means get one. I can't speak to that Meter, but it's up to an individual. All that said, once a week testing for Salt is overkill but that too is a personal choice with no wrong answer.
    Essential Links:
    May 2015
    Forney, TX
    14
    So then, how quickly should I be losing salt? Very often we will get salt up to 3200, and within a couple of days back down to 2700. According to the SWG readings.
    JoyfulNoise's Avatar
    May 2015
    13,199
    Quote Originally Posted by dirk.melvin View Post
    There's either a problem with the salt cell sensor or you have an enormous water leak, too much splash out or other water loss. If the 500ppm difference were real, that would be like 65lbs of salt in my 16,000 gal pool.
    Most of the SWG sensors are NOT temperature compensated, and there can be several hundred ppm difference between cold water and warm water.
    Matt
    May 2015
    Pooler, GA
    311
    The only thing that should be removing salt from your pool is splashout, overflows, and washing to waste. It should never come down without actually removing water and replacing it with fresh water.
    TF-100
    Helpful Links
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    If the SWG is working then all is well. If it reads low salt then you need to test. You said that it may read 2700 or 3200. That may be when it reverses polarity. I would use cheap test strips to see what you have and maybe take it to the pool store also. If it comes out 3200 or there about then you have a cell that needs cleaning or is failing.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
