Thread: Leaves in pool
    Jun 2015
    Centralia, IL
    2
    Leaves in pool
    My winter cover was destroyed in a storm last fall and tons of leaves blew in and now they have turned to muck. What is the best way to clean this mess up? Thanks to all of you!
    36' round 52" deep above ground part of it is in ground. 21" filter with Zeosand 1.5 HP pump Steel walls
    38,524
    Re: Leaves in pool
    Welcome to TFP!!!
    Pole and a leaf rake.
    Some use a leaf gulper too.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Leaves in pool
    What he said ^^^^
    Pictures of what he means in the visual encyclopedia
    Except no leaf gulper.... hmmm...
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Leaves in pool
    These guys have set you straight on the best ways to remove leaves from a pool, so I'll simply welcome you to TFP!
