Thread: Please help with getting pump to work after cleaning filter
    Aug 2014
    Friendswood, TX
    15
    We are new pool owners and having trouble getting the pump to work after cleaning the filter. It is not pumping water properly. We filled up the cleaner basket with water and it sucked it right out but then nothing else. Can you please tell me what we are doing wrong?
    New 11000 gallon chlorine IG, Tanning ledge with flolite bubblers, 2 skimmers, 6 returns, LED lights, 18" raised spa, wet edge northshore caribbean pebble finish, Jandy 2 hp VS pump, Jandy 1.5 hp water feature pump, Jandy cartridge filter, auto chlorinator, 400k btu heater, travertine paver deck, zodiac mx8 cleaner, iAqualink and spa side pda
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Please help with getting pump to work after cleaning filter
    You got a valve closed some place maybe?
    Aug 2014
    Friendswood, TX
    15
    Dumb question no. 1.... How do you tell when a valve is open or closed?
    Apr 2010
    East Texas
    9,659
    If the "ears" are in line with the pipe----it should be open.
    Aug 2014
    Friendswood, TX
    15
    Ok. We called a neighbor to look at it and he figured it out. We had also drained some of the pool water to reduce our cya so the water level had dropped about 6 inches. So, there are these white things below the skimmer baskets called waterways? And they seemed to have dropped a cover over the hole so water couldn't enter the pump from the skimmers. When the neighbor removed those things, the pump immediately starting working normally. Do you know what they are?
