Results 1 to 7 of 7
Thread: Hose bib on return side???
    Jun 2015
    Baldwin, Maryland
    146
    Love the site. Haven't had a reason to post until now. I'm re-doing all plumbing on my set up. I have seen some people put hose bibs on the return side of their pump, but can't for the life of me find what for? Thanks for any wisdom.
    38,548
    Re: Hose bib on return side???
    Welcome to TFP!!!
    Can be used to drain water off if you get a lot of rain.
    Or hook a hose to it and spray everyone in the pool
    JoyfulNoise's Avatar
    May 2015
    13,265
    PBs typically install them at the time of pressure testing and then leave them in for the customer if they want.
    Agree with jblizzle, they are very useful for slow draining excess water without having to involve the filter.
    Just put a T-connector right above the pressure side of the pool pump and glue on an NPT threaded adaptor. Then screw the spigot on there.
    Matt
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Welcome to TFP!!!
    +1
    My setup has 4 pumps, and I have one of these things on each. I've never used them. I imagine one could crack them open when the pump is priming to allow the air to escape the system before entering the filter, but I'm not sure what the benefit might be. I vote for spraying everyone in the pool.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Easiest way to do a partial drain to reduce CH buildup. The garden hose screws right on and a lawn sprinkler will screw to that.
    May 2015
    13,265
    Hahaha....except don't let those CA regulators see you doing it, you'll get cuffed and hauled off for water abuse
    Matt
    Jun 2015
    Baldwin, Maryland
    146
    Holy cow!! You guys are fast. Usually I'll post on a forum and get a response 12 hours later! I'll just add one, cheap enough. I'm still really not sure what I'll use it for, lol....
