Results 1 to 12 of 12
Thread: intellichlor reading
    Jun 2015
    Houston TX
    31
    How often does the intellichlor give a reading to the easy touch diagnostics, I added 150 lbs of salt last night, and my reading still says 1550.
    i cleaned it before i started, and she was reading 100, i added 150 lbs...that brought it up to 1550, then the following day added another 150 lbs....but still shows 1550
    thanks Bill
    IG, saltwater, intellichlor, DE, pebble, 13k gal
    Pentair easy touch, Polaris
    38,251
    Re: intellichlor reading
    The SWG should be off for 24 hours after adding salt.
    Have you tested the salt level? The SWG is not going to do a good job estimating salt levels that low.
    If the SWG is reading much lower than reality, then the cell could be failing.
    Are you using PoolMath to calculate how much salt to add?
    Jun 2015
    Houston TX
    31
    im pretty new to TFP, so waiting on my test kit in the mail. I did run it up to the pool store for a reading (3000). Im not really sure how to turn the swg off?
    i guess i could just unplug it?
    thanks Bill
    38,251
    Or set the output to zero. But if it is telling you 1500ppm and the store says 3000ppm ... I think your cell may be near the end of its life.
    Did you have the store test the cell?
    Jun 2015
    Houston TX
    31
    They said they could not test pentair?
    thanks Bill
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    how old is the cell?
    Typically, they last 3-5 years, depending of course how they have been set up, how long each day they operate and what the output of it has been over its life.
    Divin Dave,
    Jun 2015
    Houston TX
    31
    i keep getting the red flow light as well. so assume its on its last leg!
    thanks Bill
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    How old is it? Have you inspected it for calcium build up? Or cleaned it?
    Jun 2015
    Houston TX
    31
    I've cleaned it and backwash the de ... Might try changing the flow sensor
    thanks Bill
    Dec 2009
    Central Massachusetts
    2,690
    Why?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    38,251
    Because the fluctuating salt levels while dissolving, especially if very high, could damage some SWGs.
    Dec 2009
    2,690
    I've never turned my pentair off adding salt. hmmm
    The manual tells you to turn it off until you start adding salt, but I didn't interpret that as to turn it off while you add more.
    Oh well
