Results 1 to 15 of 15
Thread: SWG Experiences and Recommendations?
    Nov 2011
    Sabina, Italy
    39
    I am just about to go the SWCG route here in Italy and would very much like to hear more 'real life' experiences of using the various brands. Hayward and Pentair are available at high prices, Zodiac is more commonly available. Any help would be much appreciated,
    Cheers
    Zed
    160,000 litres (42,000 U.S. galls) 15 x 7 metres (53 x 23 feet) hybrid. Concrete floor, glass fibre walls. 1.5 HP Tifon pump, 150 kg (330lb) sand filter. Free form shape (not a straight edge in sight) 30 years old.
    Jonette2's Avatar
    Aug 2013
    Oklahoma
    97
    Re: SWG Reccomendations...In your experience, what is the best system?
    in-two, we had our pool for 1 season and it was terrible, the algae was ruining our lives. we switched to salt water and our pool is fun ! its pretty simple really.
    IG Gunite pool. 30,000 gallons. Hayward type sand filter. Circupool SI 45 salt system.
    38,371
    Quote Originally Posted by Jonette2 View Post
    Whether you had a SWG or not has nothing to do with your algae problems ... that was due to improper chemistry maintenance. You could have the same issues with a SWG.
    Jun 2011
    Long Beach, CA
    2,790
    Re: SWG Experiences and Recommendations?
    You have a large pool and should get a cell rated for 60,000 US gallons. There are only a few companies that make a cell that large and I'm not sure what's available in Italy. Post the models that you have available in that size of cell and we can offer our 2 cents from those choices.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I am very happy with my Pentair after 3 years. The Pentair IC60 would work well for you. Not cheap though.
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Or you could string 5 or so Intex SWGs together!
    Just kidding btw, although it would work.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    that is 1 big pool 42000 gallons, most definatly go with a 60k cell, you will have to run it at 70% or so and the cell will probably not last over 4 years (the higher % you run them)... it will also depend on how long you run your pump...
    May 2015
    Pooler, GA
    311
    Just curious... It is usually recommended that you go with a cell rated 2x larger than the volume. If a 60k cell is as large as you can go, then wouldn't he be better off using 2 generators with 40k cells? Much like my Intex joke, but more practical.
    TF-100
    Helpful Links
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Scuba_Steve View Post
    I say go with two 60's and be done with it. Or move up to a commercial one.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by n240sxguy View Post
    Interesting, never thought about doing that...
    like 2 of the hayward's would work well ( i would think) and be 80k, twice the size of your pool
    Nov 2011
    Sabina, Italy
    39
    Quote Originally Posted by ping View Post
    Thanks for your interest, it looks like the only fairly big swcg's available here are made by the Australian company Autochlor. They make a range that produce up to 92 g/hour, the RP 92. Plugging my numbers into their calculator their recommendation is from the 50g/hour running 12 hours a day to the 92 g/hour running 8 hours a day. Does 60k mean 60,000 US gallons? There are also Zodiac, CTX and pool pilot brands available but none advertised in the bigger (over 35g/h) sizes.
    My issue is that I'm not at the house with the pool all the time and can't get reliable manual dosing organised anymore and feel that chlorine pumps/puck feeders won't be as reliable/effective. I'm guessing I also need a Ph regulator/acid pump so any opinions on the way to go there would also be welcome. Sorry about the metric measurements, it's after midnight here by the pool and I can't trust myself to do the conversions after a few 'refreshing beverages'...
    May 2015
    Pooler, GA
    311
    Yes by 60k we mean 60000 US gallons. I just realized how ironic that is btw. Using k for kilo on top of a US measurement...
    TF-100
    Helpful Links
    Nov 2011
    Sabina, Italy
    39
    I have just realized that I asked much the same question exactly a year ago and got some good answers, duh! The beverages must be getting to me ...
    Anybody have any experience of Autochlor before I jump in with the big 92 unit?
    Aug 2014
    Mesa AZ
    54
    An ic60 (or other 60k gallon unit) would be large enough. The recommendation to go oversized is related to how often you have to replace.
    A 60k gallon unit will produce enough chlorine but you might have to replace the cell e.g. every 3 years versus 4 years.
    You still might be better off versus buying a specialty or oversize unit. If it costs 3x as much for a 90k swg but you only replace cell every 5 years it's probably still not worth the 3x hit up front.
    Mar 2007
    San Rafael, CA USA
    12,082
    It is worth getting the larger IC60 cell rather than two IC40 cells even though the IC40's will last longer (because their ontime will be lower). See Economics of Saltwater Chlorine Generators. The reason the IC60 is more economical is that the price rises much more slowly than the increased capacity. So on a $ per pound chlorine generated, it's the most economical. The IC40 is not terrible, but even those with more average sized pools should get the IC40 rather than the IC20 (unless the pool is VERY small such that the IC40 would raise the FC at the returns by too much).
