Thread: Quick ? about FC testing
    sark76's Avatar
    Jun 2015
    Secaucus, NJ
    58
    Question Quick ? about FC testing
    I am using the TF-100 test kit. While running a FAS/DPD test...When I add the R-0870 Powder to the sample while stirring. The sample does not change color one bit, even before adding the R-0871 drops. Am I to assume my FC is essentially 0? Opening pool for the first time after winter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Quick ? about FC testing
    It's either zero or you're so high it bleached out the powder. Test it again using the OTO tester that's part of the pH block. If there's none, it will also be clear. If it turns orange or brown, it's mega-high.
    sark76's Avatar
    Jun 2015
    Secaucus, NJ
    58
    cool thank you... all of the OTO tests were next to clear as well.
    Jun 2014
    15,165
    Good thing you have one of the best kits $$ can buy. Now you know what to do.
    sark76's Avatar
    Jun 2015
    Secaucus, NJ
    58
    Quote Originally Posted by Texas Splash View Post
    Great customer service as well.
