Thread: Ugly deck
    Jun 2015
    Enfield New Hampshire
    1
    Ugly deck
    We have a vinyl in-ground pool 38x18 oval with steps at one end. The deck is concrete. We had it constructed over 20 years ago. The coping was installed before the deck was poured and is set into the deck. We hired a contractor to renovate the surface by using a material that could be stamped but was very thin about 1/8" thick. He butchered the job and promised to come back and fix it. This was 3 years ago. My question is what can be done to build up the deck with the coping not removable and having no overlap to the deck surface. The concrete deck before was fine, we just wanted to give it some new life. It now is awful. Suggestions??
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,637
    Re: Ugly deck
    I do not know how deep your pockets are......................If you are able to I would think about having someone CAREFULLY chip the old stuff out and start all over. I do not know of any thing you can put over it that will not do the same thing.
    Kim
    Feb 2014
    Upstate, NY
    390
    Re: Ugly deck
    I would call several concrete companies and ask if they can grind/chip away an inch or two of material, then re-pour over.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
