Thread: Remodel - Pool Company Recommendations in Atlanta
    Sep 2014
    Milton/ga
    22
    Since I've moved into my house a year ago we have had to replace the pump, a light, salt water generator, controller, and have had 3 leaks. The tiled wall buckled and we had to have that repaired as well. The subcontractor that fixed the tile (it has come loose again) said the prime didn't pay him. The prime contractor was recommended by the pool company I was using at the time and has gone out of business. Luckily I have been able to take over the maintenance of the pool and saved money as a result, but the equipment replacement and leaks are killing me in unplanned costs. Does anyone know a pool company in Atlanta that they would recommend for equipment replacement? I believe the polaris pump is the next on the list to go. The company I use now charges $145 an hour for labor and usually an extra 34% profit on the equipment charge. It cost me $550 to have a pool light replaced. Any help is much appreciated. My newest issue is another pool leak that isn't easy to detect and may be either in the skimmer or the bottom of the pool. Also, I'm thinking I should have the pool acid washed and repainted since scaling has occured and I can't seem to control it even though the pool water levels are constantly within the saturation index range. If you have a referral for this type of work I would love the recommendation as well.
    Tracy -- 30,000 gallon in-ground gunite pool with above ground SPA (two fountains). Controller(s): Zodiac iAquaLink2.0 + Jandy AQPLM AquaPalm Salt Water Generator: Hayward AquaRite Salt Generator Complete 40,000 Gallons | Power Center and Salt Cell Kit | AQR15 Filter: Pentair FNS60 50 p.si., Model sm20-2, rated flow 125 GPM Cleaner: Polaris Heater: Pool Pump:SQ FL FR 2HP EE 230V Pentair Superflow Pump
    38,275
    Re: Remodel - Pool Company Recommendations in Atlanta
    Sorry you have not gotten any quicker responses.
    Bumping to see if anyone in GA might have a recommendation for you.
    Jun 2015
    Atlanta, GA
    640
    I had a wonderful conversation yesterday with Precision Pool Renovations. They are located in Norcross, but do work all over Georgia. They have come highly recommended to me by several companies and individuals. I was very impressed with their knowledge and the time they took with me. Waiting on estimates now.
    12K Gallon IG Lap Pool (c. 2001)
    6.6 ft x 48 ft/White Plaster/Concrete
    Pentair Superflo VS Pump 2.0 HP/Sand Filter
    Dolphin S300i Robot/SolarBreeze Robot
    TFT-100 Test Kit
    Jul 2015
    Grayson
    3
    Thanks!!!
    Sep 2014
    Milton/ga
    22
    I received an estimate from All In One Pool Construction in Lawrenceville. They were recommended by a friend. They guarentee repairs for 3 years and recommended a product called StoneScapes after replastering the pool surface. They also recommended sealing the concrete if necessary. They will seal the plaster to prevent scaling. He spent a lot of time with me explaining the process and I feel comfortable they will do a good job, but I am going to get two more estimates.
    We will need one of our walls to be properly repaired with hydraulic cement
    and pool plaster mix or hydraulic cement (without aggregate). EZ Patch 1 which is a plaster mix to build up the bed before tiling with grout.
    This is not an easy process because each layer has to dry before they can add another. I need to inspect this closely when it's under construction .
    Sep 2014
    Milton/ga
    22
    So I hired the remodel Pool Company and with the refurbishment I had two skimmers replaced. The contractor poured the concrete around paper bags which hugged the skimmers. Will this cause leaks in the future? The concrete subcontractor said they will remove the bags, but initially they are put there on purpose to hold the cement in place while it hardens and will be removed before they add the hydraulic cement that keeps it from leaking. I did a little research and typically they use a mold to hold he concrete in place or a burlap bag (not a paper bag). Should I be concerned?
