Thread: Excel spreadsheet problem
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I made a spreadsheet that I need to copy and paste to another spreadsheet. The problem is when I copy and paste the spreadsheet to where I want it, the cell information is correct but the cell formulas don't carry over to the new sheet.
    How can I correct this?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Apr 2008
    Sugar Land, TX (suburb of Houston)
    31
    Re: Excel spreadsheet problem
    To make a cell reference absolute (in other words, it does not change relative to another cell - it references cell A1, etc) either
    1) hit F4 after selecting a cell
    2) highlight an existing cell reference and press F4.
    You can tell when a cell reference is absolute when it has a "$" before each column letter and row number ($A$1)
    Hopefully that helps.
    18K (I think) gal gunite pool, Pentair FNS DE Filter, Polaris 280 cleaner, TF-100 Test Kit
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Instead of cutting and pasting the sheet (or chopping and glueing as a friend used to say), pull up the spreadsheet you want to copy, and then click on "Edit" and then "Move or copy sheet". You'll bring up a dialog box that will allow you to either move the existing sheet to another workbook, or make a copy of the existing sheet and keep it in the existing workbook or move it to another workbook. If you keep it in the existing book, you might want to rename the copied sheet, as it will keep the name as the existing sheet, plus a "(2)" i.e. "tfp" and "tfp(2)". The new sheet should have kept the existing formulae from the existing sheet.
    Mike
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I've got it to work, Thanks
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    I realize you already got it but when you right click after doing a "Copy" and instead of doing a "Paste" do a "Paste Special" this gives you all kinds of options on how you want to use the pasted data. Thought this tip may help others.
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
