Results 1 to 12 of 12
Thread: Success on my own for once! Any red flags to cause future problems?
    Newpoolcrazy's Avatar
    May 2015
    La Porte, TX
    104
    So I was losing 5-6ppm FC everyday at a CYA of 30, (good ole TX sun) so I bumped up to 50 and shot for 10ppm FC at night just in case I still lost 6. This morning at (7am) , before the sun hit, the FC held at 10ppm and my occasional pesky .5 CC or less is completely gone. Yay!
    At last test (11:30 am) 4.5 hours later with sun,
    FC = 7.5
    CC = 0
    Ph = 7.7
    TA = 90
    Cya = 50 (but not tested today. No CYA added and no water replacement since check 2 days ago)
    I think FC will hold to above 4 by the time it's ready for more bleach tonight. Haven't tested CH in awhile, but it was ok a couple weeks ago and my pool is vinyl.
    Pool is clear. I don't know if I should try to lower my TA yet, or just leave it for now.
    Am I doing okay? Do you see something I could be missing that might get me in trouble later? I think I'm understanding more, but I'm still a little skittish.
    Thanks in advance.
    Cornelius Monterey Steel/Resin AG 18' round (approx. 7600+gallons) Hayward veri-flo SWG w/sand filter.Testing w/ TK2006 using Speed stir.
    38,484
    Re: Success on my own for once! Any red flags to cause future problems?
    I would leave the TA alone if your pH rise is not excessive.
    Your FC loss should not be as high now that you raised the CYA level some.
    Sounds like you are on top of things
    May 2015
    La Porte, TX
    104
    Thanks so much. I was thinking the same thing about TA and Ph rise. Going to wait on that.
    OMG, I think I really do understand this!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    AWESOME, isn't it kewl when it clicks and makes sense
    May 2015
    La Porte, TX
    104
    Quote Originally Posted by cowboycasey View Post
    Very Cool! and kewl too
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Okay, you've got TFP figured out.
    Time to start answering questions.
    Jun 2014
    15,233
    Outstanding! We salute you!
    May 2015
    La Porte, TX
    104
    Always give back. I'll answer the ones I know for sure.
    May 2015
    La Porte, TX
    104
    FC was at 4.5 tonight (CYA 50) when it was feeding time! Woot!!!!
    Couldn't have done it without you TFP guys. <3
    May 2015
    La Porte, TX
    104
    Quote Originally Posted by Texas Splash View Post
    I don't know why, but I'm kind of excited!
    Richard320's Avatar
    Jan 2010
    19,056
    Quote Originally Posted by Newpoolcrazy View Post
    It's because it clicked. You studied the results, you decided on a course of action, you did what you needed to do.... and you were correct. And now you're marvelling that it's so easy...
    May 2015
    La Porte, TX
    104
    That's exactly it! Going to check out some "just getting started" threads and see if I can help.
