Thread: Hayward Power Cord
    May 2015
    Pittsburgh/Pennsylvania
    27
    Hayward Power Cord
    Is anyone using the original 6ft #14 awg 3 prong cord that comes with the most Hayward pumps? The tag states it is just for testing the pump and a permanent 3ft, #12 awg plug needs to be installed. I already have the Hayward Aqua Trol that is straight blade and not twist lock so I can't change the pump cord to twist lock. Is the original 6ft cord ok to use?
    21' 54" round AGP, Hayward 1hp 2 speed pump, Hayward Aqua Trol HP SWG, Hayward 150 sq ft cartridge filter
    Jun 2012
    western NY
    1,561
    Re: Hayward Power Cord
    NEC 680.7 specifies the cord length to be no more than 3' and 680.22(1) requires that assembly to be a twist lock plug/receptacle within 6' of the pool wall
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
