Results 1 to 7 of 7
Thread: Replace valves with Jandy Neverlube valves
    Jun 2010
    Toronto, Canada
    34
    I'm looking for a bit of guidance on the best approach to replacing my current valves with Jandy Neverlube valves. I currently have 4 valves at my equipment pad:
    1) Skimmer shutoff valve (before pump)
    2) Vacuum shutoff valve (before pump)
    3) Drain shutoff valve (before pump)
    4) Shallow/Deep end return jets (after pump)
    All of these can be seen in the pics I've attached. The questions I have are:
    1) Should I replace the 4 current valves with 4 Neverlube valves or would I be better of combining some of these? Should I be looking at 2 or 3 way valves?
    2) Should I be looking at making any other changes now given what is seen in my pics?
    Thanks in advance
    20,000 Gallons Inground Vinyl Pool, 1 skimmer, 1 floor drain, 4 return jets, 1 vacuum intake
    Hayward Vari-Flo XL sand filter (SM2506T), Hayward EZ Flow Pump (SP-3107X10), Emerson Pump Motor (EB228), Hayward Comfortzone NG Heater, Hayward Chlorinator (CL220)
    Jun 2010
    Toronto, Canada
    34
    Re: Replace valves with Jandy Neverlube valves
    Any recommendations from those who have done this before?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I would use a 3-way on the return side for sure. I'm not sure what the best way is on the suction side. I would want to to have a 3-way for the skimmer/drain and a separate 2 way for the vacuum, but with the vacuum in the middle it is a little messier.
    22,550
    Are you having problems with those valves, or the plumbing? If not I wouldn't replace them just to get the neverlube valves. Those appear to be full port valves, so they're not restricting the flow much if at all.
    Jun 2010
    Toronto, Canada
    34
    Quote Originally Posted by Bama Rambler View Post
    There is an air leak at the bottom of the elbow connection leading to the Drain valve. Every time I turn off the pump water leaks out of this connection and turning on this valve leads to lots of bubbles. There is a smaller air leak on the skimmer side that leads to minimal bubbles. I figured since these had to be fixed I might as well replace them with the best valves available.
    22,550
    Since you have leaks anyway you may as well change them.
    Jun 2010
    Toronto, Canada
    34
    Quote Originally Posted by pooldv View Post
    pooldv, so it sounds like you are ideally recommending the following:
    1) a 3-way on the return side
    2) a 3-way on the suction side that combines the skimmer/drain
    Besides being cheaper, what is the advantage to going with a 3-way in these two areas rather than separate 2-way valves. Isn't there more control if each line has a dedicated 2-way valve rather than combining some of them with a 3-way valve? I'm probably missing something here.
