Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Just put my deposit down (North of Kansas City)
    Jun 2015
    Saint Joseph, MO
    34
    I just put my deposit down on a new pool construction. It's a steel wall, vinyl liner pool. Mountain pond style, 40'x20'. We have chosen salt as one of our kids is sensitive to high chlorine levels. I will be posting pics whenever we get started (as much of you already have had to endure, it's been raining a lot in the KC area). My builder has a couple days of work (provided it's dry enough) on his current build before he starts mine.
    Two questions (the first of MANY, I am sure):
    What size (hp?) pump should I be requiring. I believe the quote was for a 1.5hp pump. Should I upgrade? Or, is that enough?
    One LED light is included. Another will add $900 to the bill. Seems steep...opinions on additional lighting?
    Jul 2013
    Wichita, KS
    55
    Re: Just put my deposit down (North of Kansas City)
    Quote Originally Posted by wallywest View Post
    One of our big regrets with our pool in Wichita was not adding more lights. We put in a 18X36 inground pool with a deep end. The big light in the deep end is pretty bright but it doesn't properly light up the shallow end. If we had the chance to do it over again, we would have put at least one smaller light if not two..one on both sides of the shallow end (that sync with the bigger light (i.e. light displays).
    18 X 36 (21,000 gallons?), IG Vinyl, Tagelus High Rate Sand Filter (Model TA 60/60D - 60 gpm), 1.5 HP Waterway 48 Frame Special Flow Rate Pump (Model SMF-115), Installed June/July 2013, Auto Polaris Cleaner with separate pump, Inline Chlorinator (NOT USING - Using the BBB Method), Waterfall, Stadium Seating Entry, TF-100 w/ SpeedStir (Wichita, Kansas)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome to TFP!
    Chlorine levels in properly maintained salt pools and standard chlorine pools are about the same. Actually the same is true for tap water. But a SWCG is a good choice for chlorine generation. The key is understanding the chemistry, and this is the place to learn it.
    Pump size depends on many things: Pool size, water features, debris load, electric rate etc.. Builders tend to oversize the pump and undersize the filter. Often a two-speed pump is the best choice. More than likely a single speed 1.5HP pump is too big for your pool.
    Lights are very much a personal choice. You may want to see pools with the lights you are getting at night. LEDs don't put out as much light as halogens, so you may need or want two lights. I don't use my light for swimming because it ends up drawing bugs, but it's a great safety device and really handy when cleaning up at night.
    You may want to consider a pipe size upgrade. 2" pipe is much better than 1.5". If you are getting a main drain, make sure you are getting one independently plumbed rather than one plumbed through the skimmer.
    Post your quote/drawing or questions. Many of us have been through the process and can give you our lessons learned when we did it.
    Jun 2015
    Saint Joseph, MO
    34
    Quote Originally Posted by JohnT View Post
    Welcome to TFP!
    Thanks for the responses.
    We are getting 2" pipe already.
    I will check on the main drain being separate, and I will check on getting a multi-speed pump.
    When you say "undersize the filter", can you be more specific for me? I don't want to fall into that trap.
    SW Indiana
    9,199
    Filters are generally specified by flow rate. Larger pumps are a cheap upgrade, and many people like the idea of more HP. To inexperienced people, a filter is a filter. If you get a filter that is undersized, it may filter the pool okay but require frequent cleaning. You can even have a filter enough undersized that it restricts the flow of water from the pump excessively. Cartridge and DE filters are generally specified by square footage, and sand filters are specified by diameter or pounds of sand. You'll be happier with the biggest reasonable filter. What kind of filter are you going with?
    Jun 2015
    Saint Joseph, MO
    34
    I am going with a sand filter.
    SW Indiana
    9,199
    Generally a 24" sand filter is just adequate for a 1HP pump. A 30" filter would be a good choice with a 1HP pump or with a 1.5HP two-speed.
    Jun 2015
    Saint Joseph, MO
    34
    Thanks!
    Jun 2015
    Saint Joseph, MO
    34
    Ok...the rain here in KC (mostly earlier in the spring/summer) really has contractors backed up. We had construction actually start on 7/22. The dig is done. Panels are set. Footers poured. The plumbing is largely done. Backfilling has started. Waiting on the wall builders now, but I am worried about how long they might take. Here are some pics:
    csmith78's Avatar
    Jul 2015
    Tomball TX
    93
    What a beautiful place to put a pool!
    18.720K gallons. Geometric pool with Spa. 16-6'x40-13'; 512sf; 116ft perim; depth 3.6'-7'. 7' raised spa, 6 jets; Jandy equipment; 2 color LEDs; 3 deck jets, 3 stone scuppers, 21'-12" raised wall Ledgestone, 13'-18" raised wall ledgestone, 2-2x2x2 pillars with Ledgestone.
    Jun 2015
    Saint Joseph, MO
    34
    Thanks! Can't wait to get the retaining wall in...I think it will help a lot on seeing the final form.
    zombiejeep's Avatar
    Jun 2015
    Nebraska
    39
    Looking forward to seeing this develop, It looks nice! We just had an AGP put in a couple weeks ago an hour and a half north of you. Builder was delayed due to the weather as well.
    (by the way, I was born in St. Jo, it's my old stomping ground.)
    21' Revelation AGP ~10,500 gal, Pentair SD60 Sand Filter w/ 1 1/2 HP Dynamo Pump, TF-100 Kit
    Installed 07/25/2015 with city water.
    Jun 2015
    Saint Joseph, MO
    34
    Anyone know the best pool volume estimator? Builder says the docs say 22K gallons with no deep end. That's the best I have now, and I am just looking for an estimate.
    40'x20' "Mountain Pond" inground salt pool, 22,000 gallons, vinyl liner and 8' deep end; Pentair products: SuperFlo single speed 1HP pump, Tagelus TA 100D filter, MasterTemp 250 heater, IntelliChlor salt chlorine generator, IntelliBrite 5G White LED light
    Jun 2014
    Roseville, CA
    345
    You might be able to rent a meter from a rental yard, or buy one for your first fill.
    water meter | eBay
    (The couplings don't look right, so you might have to mickey mouse it)
    It's important to know. I always thought I had 15,000 gals, when actually I had 14,000. Not a huge deal, but it's nice to be specific when asked.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Jun 2015
    Saint Joseph, MO
    34
    We FINALLY got our retaining walls in. The pool builder back on site today prepping for pool krete. Finally going to get some more progress.
    I want to post some more pics, but it's telling me that the picture "exceeds my quota". What am I doing wrong here? The first couple posted nicely.
    SW Indiana
    9,199
    Members have limited picture storage on the forum. You can either become a supporter, which gives you extended picture storage, or you can use a site like Photobucket and link to the image there.
    Jun 2015
    Saint Joseph, MO
    34
    Never mind on the photo question. I found the answer in the FAQs (like I should have before asking). Here are a couple more in progress pics of the walls.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    WOW what a wall.
    Is that like 25 ton of rock?
    That looks so cool.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Yeesh! The fist pic is probably my favorite under construction pic yet. And the last one...so sad about Stonehenge.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  20. Back To Top    #20
    Jun 2015
    Saint Joseph, MO
    34
    Quote Originally Posted by ozdiver View Post
    WOW what a wall.
    That looks so cool.
    HA!
    There were five (yes, 5!) dump truck loads of stacking rock. The first two were 23 tons EACH. The last three were all "heavy" per the wall guy. We ended up with 18 full/partial blocks left over. All in, I think we used 100 - 110 tons of stacking rock. Then there were 66 tons of gravel delivered too. That wasn't enough, and we are getting more today.
    The walls ended up being 475 sq feet and 89 sq feet respectively. The big one is right at 100 feet long at the top course. The "small" one is 35 feet long. Each of the stacking blocks are 14" tall on the front face. Some are nearly four feet deep from front face to back face.
    And sorry about those pics...they are in reverse chronological order.
