Results 1 to 7 of 7
Thread: Pool chemistry
    Jul 2014
    Memphis/MI
    20
    Pool chemistry
    I live in Michigan and just opened my pool (20x40 gunite) last Friday by adding @ 7,000 gallons of fresh water. My pool has a capacity of @ 35,000 gallons. I've vacuumed the pool and replace the 4 filter elements and added 6 gallons of 12.5% chlorine for the past four days. The following are my current chemistry levels; FC - 1.0, CC - 2.5, PH - 7.2, CYA - 0, TA - 130 and my CH @ 700. The water is clear. I would appreciate any recommendations on next steps. Dan
    35K gallons, IG 20x40 rectangular Gunnite, resurfaced 2009, Cart filter (4 elements), Pentair 1 HP main pump model CX, Pentair 250M heater, Polaris pool vacuum.
    Jun 2014
    15,103
    Re: Pool chemistry
    Hello Dan. Here's what I see (others will follow):
    1 - Get stabilizer in there ASAP to increase your CYA shoot about 40 (use sock method)
    2 - With no CYA, your free chlorine will go fast. Consider putting enough regular liquid bleach in there to stay at 2ppm readings until CYA can protect higher FC of 5 or so.
    3 - Seeing that your CC is 2.5, you may need to perform a SLAM in the near future (link below), but your CYA needs to get up to 30 first.
    30,419
    Re: Pool chemistry
    +1 what Texas said
    Jun 2014
    15,103
    Re: Pool chemistry
    Use the poolmath calculator (link below) to figure out exactly how much stabilizer and/or chlorine to add. If you have more questions, just ask.
    Jul 2014
    Memphis/MI
    20
    Re: Pool chemistry
    Just so I'm clear. I should add about 12 # of powered stabilizer to increase the CYA level and also add liquid chlorine to get the FC level up to 2ppm ASAP. The pool calculator calls for 187oz of stabilizer, just under 12#, and 487oz of liquid chlorine to raise the CYA. the reason I'm asking is that I've been putting in 6 gallons of chlorine (768oz) over the past four days and the CYA is still 0. Dan
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Re: Pool chemistry
    Quote Originally Posted by DAN1925 View Post
    If you are using liquid chlorine the only thing that will raise CYA is to add stabilizer. Adding pure chlorine adds nothing but chlorine.
    I would follow Texas Splash's advise, then SLAM the pool before whatever is brewing in there gets worse.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2014
    15,103
    Re: Pool chemistry
    Yes Dan, just focus on the stabilizer to 40ppm and only 2ppm of chlorine (bleach) for now. The reason being is that even if you tried to put more bleach in (i.e to hit your ideal FC) your pool can't hold it. It doesn't have the CYA to protect it. So just get that sock full of stabilizer in there for now (squeeze it from time to time) and make sure you keep at least 2ppm FC in the pool (the sun will take it fast), but do your best to stay on it. Once your CYA is back p to the 30s - 40s, you can start increasing the FC to your ideal target level and the pool will hold it better.
