Results 1 to 10 of 10
Thread: Scrubbing
    Jun 2015
    Bessemer,Mi
    42
    Scrubbing
    How often and how necessary should I need to scruby my
    vinyl pool ? I mean if the chlorine is kept up and no algae is able
    to form what am I scrubbing ?
    16x48 intex ultraframe. 5300 +or-
    cheapo intex filter for now.
    Taylor k2006.
    Working on the partial wrap around deck
    NEED to add a skimmer!
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: Scrubbing
    I brush mine once a week
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Jun 2015
    Bessemer,Mi
    42
    Re: Scrubbing
    But what are we brushing if there is no algae?
    Taylor k2006.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Re: Scrubbing
    You're brushing, not scrubbing. A pool brush is pretty much just a stiff push broom.
    For whatever reason, dust and pollen that lands in the pool likes to stick to the wall. Consider it dusting, not scrubbing. You just want to get it off there and into circulation so the filter can grab it.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Scrubbing
    Plus, it gives you time to reflect on how great your pool looks.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Bessemer,Mi
    42
    Re: Scrubbing
    Good point!
    Taylor k2006.
    Jun 2014
    Rogers, AR
    424
    Re: Scrubbing
    I LOVE to brush my pool! It is so therapeutic. I usually do it late at night with the music on, a big cup of coffee and everyone has gone to bed. I do mine multiple times a week. I also have a robot that gets used pretty much daily. I can tell when it needs to be brushed the ole Z just doesn't get it it quite like I do.
    A lot of times I am running the robot at the same time and I talk to it when it surfaces. My neighbors must think I am nuts.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Scrubbing
    Sometimes I can get through two beers or cups of coffee brushing my pool. I usually do it early in the morning or late in the evening to avoid the heat. Peaceful.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Scrubbing
    I don't mind brushing at all. Vacuuming....that's what Robots are for. I hate it.
    Essential Links:
    Jun 2014
    Rogers, AR
    424
    Re: Scrubbing
    Quote Originally Posted by Patrick_B View Post
    Me too! If I need to do touch ups I use my Pool Master. I would rather walk over hot coals than do a vacuum. I don't even vacuum in my house. I use the Roomba!
