Thread: Trying to Decide Finish prior to meeting with Builder
    TsTime's Avatar
    Jun 2015
    San Diego CA
    16
    Hello all, we are in the design stage and the pool finish is a BIG financial and desire decision for us. 2 catalogs left from prospective PB's are from Gemstone and NPT. We were leaning towards plaster for financial reasons but understand the builders do not warranty them and want to get it right at first after reading "change order" threads. Another consideration is feel to the foot, we have infants and my wife's feet can be sensitive so the right decision is important. My questions are
    Gemstone vs NPT, same quality & cost?
    Is mini pebble same as pebble sheen?
    Is the quartz finish an economical alternative?
    Does the stone or quartz finish offer that much sparkle and warranty to justify?
    I am confused why the builders would not warrant the plaster?
    Next question is for thread start or continue existing. When I start this "finish thread" do I start a new thread for "Questions for Builder". Thanks for reading.
    In design and proposal stage: 46'x10' - 2ea 2'x10' 8" & 12" deep Baja Steps - 4-7' Deep - 2 Sheer Descents - 15,000 gallon in ground - Automatic Cover (under coping)- SWG - 400,000BTU NG Heater - Unknown size/brand pump(s), filter, LED, cleaner type and pool finish
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Re: Trying to Decide Finish prior to meeting with Builder
    We went back and forth with this decision for weeks. We finally decided on Wetedge Satin Matrix line. It's a pebble but it's smooth pebbles. We came to this by seeing both Quartz pools and pebble pools. The pebble pools held up better. Saw both finishes on pools that were 5 years old, and the pebble looked brand new.
    Here is a pic of a Quartz pool someone posted on here: see the discoloration?
    That pool was 9 days old and I bet the builder got most of it fixed with an acid wash. But you have to make sure your chemicals are near perfect for the Quartz to look it's best.
    Yes pebble is a bit more money but worth it in the long run.
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Welcome to TFP.
    You can keep all of your build related questions in this thread for continuity and future reference.
    Yes, quartz is an economical alternative between plaster and a pebble. There are lots of happy quartz people here.
    Any pool surface is going to be rough on your feet after a point when rough housing. I have had sore feet from plaster and from pebblesheen. No experience with quartz. I don't rough house nearly as much as I lounge. But, I can certainly play in the pool for hours without my feet being sore. Last time my feet hurt was a 3 day pool party and I was in the pool a LOT with teenagers and such! I wonder if our feet toughen up over time because it certainly has been a while since I had sore pool feet. We swim nearly every day in season.
    TsTime's Avatar
    Jun 2015
    San Diego CA
    16
    thanks so much for your takes and photo and advise on thread activity. I will search more in forum re quartz. Below is a list of questions for potential builders interview, please critique and add thanks
    4-7-4 Depth
    Middle Bench 8’
    Skimmer(s)Placement
    Water fill location
    Bond beam explanation
    Coping Precast or pour
    Tile is there a store or samples
    Drains and location
    Water inlet returns
    Finish: quartz or pebble sheen
    References :2 builds in progress3 most recent 2-5yrs built
    Equip.(Pool Serviceby Contractor)
    2 speed VS variable and size
    Filter type and size
    Heater for size-spa
    Cleaner Robot VS suction
    SWG Brand
    LED 5g intellicolor2for pool & 1 spa
    Pipe size & why
    Slide type brand
    Auto cover brandSWG Wanted?
    Automation control brand
    Descent pump
    Spa pumpJet # Types
