Thread: AquaLink One Touch rapidly cycling cleaner
    Jul 2010
    Houston, TX
    3
    When I got home yesterday, my cleaner was still running - the system should have shut it off. I didn't think too much of it.
    About 2:30 this morning, I was woken up by a pump rapidly cycling on and off. Went outside first - it was the main pump. When I went back inside to the One Touch, I could see it was actually the cleaner cycling on and off, causing the main pump to come on as well - the cleaner didn't have a chance to come on pending the "safety window" with the main pump running, I think?
    Anyway... I flipped the breakers, deleted the program entry for the cleaner... and that's about as far as I could think at 2:30AM. I left the breaker to the pumps off for the day, but obviously I can't leave it like that.
    Suggestions???
    ~20K in-ground with attached spa; Jandy Aqualink RS with One Touch controller
    AO Smith Centurion 2HP main motor with Challenger pump - can't read model; Hayward Progrid DE4820 filter
    Magnatek 3/4HP booster pump for cleaner; Magnatex 2HP with Whisperflow pump for waterfall
    Mini Max XL 400 heater (in Houston!?!?)
    38,540
    Re: AquaLink One Touch rapidly cycling cleaner
    Sorry you have not gotten any quicker responses.
    I am not familiar with that system, maybe someone else can help.
    Jul 2017
    Pearland/Texas
    1
    I'm having a similar issue. Were you able to find a resolution?
    Jun 2012
    NASA/ TX
    42
    Is the air temp sensor working and reporting correct value? I've not experienced this, but my first thought is if the freeze protect is being enabled to due a mis-reporting temperature value.
