Thread: Quick question
    Jun 2015
    Bessemer,Mi
    42
    Quick question
    If I maintain my free chlorine at all times. At least above minimum required
    Will I ever have an algae issue? I can't imagine I would
    also. If I am maintaining my pools ph and FC. I should never need
    slam throughout the summer. Correct?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Quick question
    While we can never say "never", yes - if you maintain your FC above the minimum based on your CYA level you should never get an algae bloom.
    No, you only need to SLAM if you have an issue (cloudy pool/visible algae).
    Where pepople get in trouble is that they become complacent. Tabs are easy and they just start using them all the time, not accounting for the rise in CYA. Soon they are not keeping sufficient chlorine in the water. They skip looking at the pool for a couple of days and boom, it's green.
    You are in the good position of dumping all your water and starting over if you have an issue
    Support the site
    Jun 2015
    Bessemer,Mi
    42
    Re: Quick question
    Ok. Thanks. I'm anal about stuff so I should be ok.
    My cya is LOW as I haven't even gone through a puck yet. I use bleach
    for maintains levels. Puck to help and to raise my CYA up. All seems ok so far
    but hasn't had any hard swimming temps only at 65 and has been covered a lot
    May 2014
    Franklin, NC
    9,179
    Re: Quick question
    Well, one puck should raise your CYA about 11, so 5 pucks gets you to the mid 50's. A little slow to get there, but it will work. I have 4 pucks floating in my pool now to bring the CYA up a tad.
    Support the site
    Jun 2015
    Bessemer,Mi
    42
    Re: Quick question
    Maybe I should so that too. Add more pucks to floater!!'
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Quick question
    For those of us that have followed the TFP method for several years, it seems the only time an algae event happens is when something major goes wrong, such as storm water entering pool, or possibly an equipment failure where there is not enough circulation for a prolonged period.
