Thread: new connections keep leaking or cracking
    Jun 2015
    Farmersville
    2
    Question new connections keep leaking or cracking
    First our old Hayward pump failed. I bought a new pump by tidal wave and we had to switch from the hard pvc to hose as the old connections were fitting. However now it seems that the connection that screws into pump and connects to hose via clamp keeps leaking at both pump and filter. We have had two Crack on my husband. We used plumbers dope instead of Teflon and it does not seem to matter. Any suggestions.
    I have above ground 5 year old vinyl 15 foot round 5ft deep pool original Hayward 2.0 pump with filter set up. Now a tidal wave 1.5 pump , connected to same Hayward cartridge filter. Original hard pvc pipes from pump to filter but now it is hose.
    Jun 2014
    15,193
    Re: new connections keep leaking or cracking
    Hello and welcome! Is there any chance you might be able to post a pic of the area to show the new hose, clamp and pump fittings you are referring to?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also can you edit your location to give us a State also, it helps knowing where you are to answer questions, including ones like this.
