Thread: Skimmer not working with suction pool cleaner
    Apr 2015
    Phoenix, AZ
    5
    Hi Everyone,
    I have my TFTest kit now and am making good progress in getting all the levels where they should be.
    I just got a new automatic cleaner, the 4 wheel Pool Cleaner. When I turn the suction up to the level it needs to be (11-13 RPMs) it seems like the skimmer is no longer working.
    Does anyone have experience with this? Are there ways to fix it?
    Thank you!
    25,000 gallons, plaster, sand filter, in-ground
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Skimmer not working with suction pool cleaner
    Welcome to TFP!
    Does your pool not have a dedicated vacuum line?
    Essential Links:
    Jun 2011
    Carlsbad, NM
    172
    What pump are you running? If it is a small pump, it may not be able to run both.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Apr 2015
    Phoenix, AZ
    5
    I know the pump is small, smaller than it should be for the pool size so that makes since that it may not be able to run both. I do have a dedicated suction line.
    Thank you both for your responses!
