Thread: Keep getting check cell light
    May 2014
    Hesperia, CA
    4
    I installed the CircuPool Si 45 plus last year after using liquid for 3 or 4 years after my Aquapure 1400 quite after 5 years. The Si 45 plus had a 7 year warranty and has only been in use for a year. I have flushed it out with water and used the acid mixture to remove the build up. I have been checking it daily starting on Fri 5 June and it does not work with out the acid wash. If i need to clean it every day does that mean it is going out? I like when I don't have to add the chlorine all the time. Does anyone have any experience with the CircuPool brand?
    34K gal, In-Ground, Gunite, Jandy equipment is 10 years old, 3 returns,
    Jandy CL460 filter, Stelth 1.5 hp mod# SHPF1.5 (new motor 2 years old)
    Salt system is CircuPool Si 45 plus (1 year old) Replaced AquaPure 1400 (5 years)
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Keep getting check cell light
    I've only had mine a a little less than a month. I assume you got it from discountsaltpool.com? Call them and see what they have to say about it. They've been very nice and knowledgeable when I've called.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2011
    Long Beach, CA
    2,790
    Is the cell actually forming white scale that often? Do not clean the cell if there isn't any scale as something else is the problem.
    May 2014
    Hesperia, CA
    4
    I did call them today from work and they said the system may need to be re-set. I am off on Friday so I will call when I am by it and they will walk me through the process. It has worked for two days in a row so far. I installed the cell backwards also to see if it makes a difference. Thanks for the advice.
