Results 1 to 9 of 9
Thread: Broken valve
    Jul 2008
    Cape Coral, FL
    24
    Broken valve
    When we bought our house we had 2 valves that had one ear broken off. One for the slide and one for the waterfall. Well today my wife broke the other ear off the waterfall valve and I'm sure the other ear for the slide will go soon.
    Looking at what I have is my only course of action here to replace the whole manifold since everything is glued? Would it be wise to put couplers on each line coming from the ground to the manifold in case another valve breaks so I don't have to keep cutting pipes and glueing new valves in?
    90ft perimeter plaster pool, 14000 gallons, plastic slide, rock waterfall, Bahama step, Polaris Auto Clear Plus SWG, a pump and filter( will update later)
    30,424
    Re: Broken valve
    It would be quite difficult to fit unions on those valves without elevating it significantly to get some extra space. Generally, I would say it would be a big PITA to do.
    You could replace the ball valves with brass but that's pricey.
    You could simply remake the existing manifold and resign yourself to replacing them if they break......that would probably be my choice.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Broken valve
    Just because I'm a cheapskate - I'd use channel locks to turn those valves for now As long as the balls in them are holding, it's just an issue of being able to adjust the flow through them 8)
    Otherwise, I'd go with Dave's suggestion and replace the whole manifold when the time comes.
    Welcome to TFP!!
    Ted
    Luv& Luk
    -Ted
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Broken valve
    Whenever you decide to redo the valves, I'd take the opportunity to better accommodate your SWG, which will involve moving the filter, which means changing everything from the pump to the return valves.
    Depending on what your weather is like now, I'd wait to do the job until the spring when it's a bit warmer out and the glue will set better. Maybe you'll get to enjoy the wrench method in the meantime.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Broken valve
    I'd drill a hole thru the old handle and insert/attach a long bolt or threaded rod.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Sep 2007
    Lafayette, Louisiana
    344
    Re: Broken valve
    I have some of the same ball valves on my manifold. Those look like Jandy Goldline valves, same as mine. My pool is brand new this summer and I did all the plumbing myself and bought only quality components (I thought). I broke one of those handles off myself on Saturday. This valve is only 4 months old and now I'm using a pair of channel locks myself to operate it. I'm kinda ****** about it actually. The Jandy NeverLube valves seem to be of very high quality and are repairable/serviceable. If I replace them I'll bite the bullet and pay the extra for the NeverLubes. I won't ever use the Goldline valves again.
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    Dec 2007
    Central New York
    504
    Re: Broken valve
    For my two cents, I would replace the manifold and valves.
    For the fittings.
    http://www.flexpvc.com/
    For the valves.
    http://www.westsidewholesale.com/index. ... 2.8417@@@@
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Re: Broken valve
    If you decide to replace them, use a good quality union ball valve like a Praher. These valves have removable handles and a union built in for servicing the ball/seals if you ever need to.
    http://www.prahervalves.com/pagespool/s ... nion2.html
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Broken valve
    I'm seeing nothing but re plumb here. Jandy Never lube valves? Absolutely, They should call them Never replace valves. Whats great about these is that they come in a couple of different configurations. Two-way, two-way 90, and 3way. The 1 1/2 can accommodate 1 1/2" and 2" pipe. And the 2" can accommodate 2" and 2 1/2" pipe. They also offer check valves that use the same body. You will never have to replace these valve bodies. Period.
    Factory Warranty Station for:
