Thread: New fiberglass over gunite finish, how long before NaCl?
    Nov 2010
    DFW
    29
    Question New fiberglass over gunite finish, how long before NaCl?
    Long story short. 20+ year old gunite + plaster pool, 135ft of cracks. Nightmare. Considered many options but chose a local highly review FG company that offers 5 yr warranty on finish and staple crack repair. Closest I got on plaster was 6 months cracks, none on finish. FG is a little more expensive but very easy to repair, looks like plaster and am hoping it will be a bit more flexible should any more shifting occur.
    So... tomorrow finally will be the gel coat. Once I get this thing filled again I'm prepared to balance and run with bleach for awhile if I need to. How long should I wait before adding salt?
    18,000gal IG with FG finish + spa, Pentair CCP 420 filter, Pentair VS pump, Hayward AQR15 SWCG, Polaris 360, 325k BTU heater...
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: New fiberglass over gunite finish, how long before NaCl?
    Might be best to ask the installer. That way you don't void the warranty by getting the wrong advice.
    Would love to see pictures!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    That sounds like an interesting process, seems like that would work better. Dang black clay! No idea on how long to wait on the salt add.
    Nov 2010
    DFW
    29
    Here are some pics after the first coat of gel. Happy to answer any questions on this. Seemed like a pretty ideal mix of construction, materials and durability to me. I know many are hard on pure FG pools, but IG + FG seems like a pretty good mix (hoping).
    One thing that is concerning is the amount of water BENEATH the pool structure. We had a month of torrential rains here a week ago but there is a constant supply of water below after removing >60 gallons.
    Nov 2010
    DFW
    29
    Ok project is finished. Really pleased with the results. General guidance on the original question was balance first then add salt. Usual FG call out about watching your CH, too low is very bad but 50 ppm lower than a traditional plaster pool. So far I'm happy.
    For anyone else wondering, to go the FG route is about the same cost as going with a premium quartz plaster finish. FG over IG should last upwards of 20 yrs based on what I've read...
