Thread: What is this?
    Jul 2013
    Rancho Cucamonga, CA
    15
    What is this?
    Just bought a new home (to us) and inherited a pool. Working on getting all the chemistry balanced and going well.
    Have a Hayward navigator pool cleaner and this contraption was attached to where the hose plugs into the skimmer. Seems the valve would open to prevent all the water from being sucked through the hose/cleaner but I'm not sure of its purpose. Any ideas?uploadfromtaptalk1433816402666.jpg
    ~20,000 IG Roman Shaped Plaster Pool with Spa
    Cartridge Filter (Hayward C4025)
    Pentair Supervlow VS 342001
    TF-100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What is this?
    I am guessing it is some type of variable pressure bypass regulator for the suction cleaner, it is used to turn down the suction if your pump has too much flow.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Re: What is this?
    yes it is an MB valve which comes with Zodiac cleaners. It is used to regulate the water flow through your suction cleaner when connected to your pump.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Jul 2013
    15
    Re: What is this?
    Thank you! That's what I figured. I'll mess around with it.
    TF-100 Test Kit
