Thread: Spa/Pool Na;rural Gas Heater Recommendations
    May 2015
    sacramento ca
    26
    Hi,
    We are looking to buy a new Spa/Pool Natural gas heater. We have a 19,000 gal pool w/ spa. The old heater that no longer works is a comfort zone (Hayward). I think we are looking for a 350 BTU size unit.
    Would you be able to share your experience with the Hayward Natural Gas Heaters? Or recommend another brand that you have positive experience with?
    I am in Northern CA - and mostly want it for spa use a couple times a week and to heat up in about 30-60min. Might use pool heater a couple times a year, but not expecting much use.
    Thanks for any advice.
    Jun 2012
    western NY
    1,562
    Re: Spa/Pool Na;rural Gas Heater Recommendations
    Almost everyone on here recommends Raypac. 350,000 BTU should bring your pool temp up almost 2*/hr. I have a Hayward (small one) that can be a bit finicky at times. I have replaced a couple of the troublesome parts with more durable components so I don't have the problems most people have. Most any heater can be repaired/put back into service. It is just how much you want to fight with it to do so. With me it is something of a hobby to keep old relics running (cost conscious of course)
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    +1 on a Raypak. A Raypak 266K BTU or 333K BTU would take care of your needs.
    Hayward's are not without their problems.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
