Thread: Tmonster here, ya'll!
    Jun 2015
    Waco, TX
    3
    Hey thanks for this awesome resource. I'm in Texas and a three-year veteran of Intex above-ground pools. Started with a 15'x48" metal frame that we used for two years. The bottom liner just wasn't going to make it a third, so this year we upgraded to a 22' x 52" ultra-frame pool. I learned much the first couple of years from another forum similar to this I think, but I cannot locate it anymore. I am an avid follower of the BBB method and am always looking to educate myself further. With a bigger pool this year, I'm having to reconfigure my chemistry but it should not be a problem. Mainly I'm considering leaving this new behemoth up through the winter and came here snooping after deck/structure ideas for now.
    Love what I've seen so far!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Tmonster here, ya'll!
    welcome, enjoy perusing
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Welcome!
    Check this deck thread. intex pool and deck build
    Jun 2015
    Waco, TX
    3
    That is just the kind of size and scale I had in mind. Looks great! I'm hoping to incorporate a very stable ladder or stairs that will accomodate our aging parents as well. They really want to swim with the grandkids.
    Intex 22' x 52", Sandpro 4510 filter .5 HP
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
