Results 1 to 15 of 15
Thread: Confused New Pool Owner with New TF-100 Test Kit
    Jun 2015
    Winfield, AL
    7
    Ok I received my new TF-100 testing kit in the mail and once I found instructions on how to actually use the testing kit i've come up with these test results...
    TC=1
    PH=6.8
    FC=.5
    TA=80
    CH=40
    CYA=0
    Our water is blue but so cloudy that you can't see the bottom!
    My question is...should I start with doing a SLAM or follow the Pool Math calculator and add what it is telling me?
    Intex AG Pool
    7646 gallons
    Krystal Clear Sand Filter Pump 16" & Saltwater System
    Model CS20110
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Confused New Pool Owner with New TF-100 Test Kit
    Welcome to TFP!!
    Great job getting the best test kit!!
    Put the amount of CYA Pool Math says you need to get to 30, place it in an old sock and hang it in the water, preferably in front of a return. Leave the SWG turned off.
    Use Borax to to get the pH up to the low 7's, like 7.2 - again use Pool math to figure out how much you need. Borax is available as 20 Mule TeamŽ Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
    Then ignore everything else and SLAM the pool.
    If you are unsure of how, read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    * CC is 0.5 or lower;
    * You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    * The water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    awesome on getting your test kit We will get you going soon..
    30,419
    Welcome to the forum.
    You are not far off. Let's start with what problems you have...
    Low pH
    Cloudy water
    Virtually no FC
    No CYA to protect the FC.
    Pump running, First bring your pH up to 7.2 using PoolMath to dose.
    30 minutes later, bring your CYA up to around 30 ppm. Dose accurately so you don't overdose but now you can assume the CYA is in your pool....even though it won't yet show up on your test.
    Now, you are ready to SLAM your Pool and get it crystal clear. SLAMming is a process so be sure you read the entire SLAM article before you start.
    Use the Chlorine/CYA chart in Pool School to tell you haw much to dose but I can tell you it will be about 20 ppm FC. Then you HOLD the FC at the SLAM level for however long it takes for your pool to get clear.
    We'll help along the way.
    Jun 2015
    Winfield, AL
    7
    Ok Tim this is probably a stupid questions but is a SWG (saltwater generator, right?) and a saltwater pump the same thing?
    Intex AG Pool
    7646 gallons
    Model CS20110
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by aj2015 View Post
    Yes, the salt water system creates chlorine via a chemical reaction once you get the proper amount of salt in the water. Lets get the water clear before we worry about that.
    Dave did correct me on a key point, the pump should be running - so don't confuse the salt system with the pump.
    Support the site
    Jun 2015
    Winfield, AL
    7
    Thanks Duraleigh and cowboycasey! Will start working on my PH and CYA and then let you know how the SLAM process goes. I am away from home for 12 hours each day Monday - Friday. How will this affect the SLAM process?
    Ok thank you Tim! Just wanted to check before I started!
    Intex AG Pool
    7646 gallons
    Model CS20110
    May 2014
    Franklin, NC
    9,184
    It will slow down the SLAM, but if you test and adjust before you go to work and then a couple of times after you get home before bed it will clear up.
    Support the site
    Jun 2015
    Winfield, AL
    7
    Ok thank you so much! Just wanted to check before I started!
    Intex AG Pool
    7646 gallons
    Model CS20110
    Jul 2013
    Fletcher, OK
    3,353
    before you go to work take it above your shock level 3 to 5 fc, so if your shock is 12 (CYA 30) take it to 15 and see if it is close to 12 when you return
    Jun 2015
    Winfield, AL
    7
    Ok I have another question. If I need to hold the FC level at a 12-15 during SLAMming and my FC test kit only shows a max of 10 then how do I know what the exact level is? Do I just assume as long as it reads more than 10 and once it reads at level 8-10 then I add the recommended amount of bleach to increase it back to the FC SLAMming level?
    Intex AG Pool
    7646 gallons
    Model CS20110
    30,419
    If you have the TF-100 test kit, there are two chlorine tests....one that goes to 5 ppm and one that goes easily to 50+ ppm.
    What kit do you have?
    Jun 2015
    Winfield, AL
    7
    I have the TF-100 kit. My kit didn't have detailed instructions so I'm using instructions that I found on this website. I'll look and see how to do the test to 50+ ppm. Thank you I wasn't aware of that!
    Intex AG Pool
    7646 gallons
    Model CS20110
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Just use the DPD-FAS test. That is the one where you have to pour in a scoop of powder first. The detailed instructions are on a waterproof card just a bit larger than an index card btw.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jun 2015
    Winfield, AL
    7
    Ok thank you. I will do that when I get home from work. Thank you!
    Intex AG Pool
    7646 gallons
    Model CS20110
