Results 1 to 10 of 10
Thread: Ecopump first electric bill
    Jun 2015
    Temple,Tx
    12
    I've tried to find info on forum about Ecopump pool pumps and it seems the general opinion is that it's not all that impressive and it's basically a high priced multi speed pump. The Ecopump is made in Goergetown,Tx about 45 min south of my locale plus the fact it's got the 3 year warranty is what sold me. I just got my first electric bill and running the pump 24/7 and 1-2 hrs a day on high with the booster pump my bill was $10 higher than the previous month. I pay .08 cent per KW. I gotta say I am really pleased with the pump. Does anyone else have #'s for the pumps your running,just to compare? Thanks.
    15,500 IG Fiberglass (Lonestar pools) Charleston 16.5"x37, Pentair DE flt fns Pls48, Ecopump EP-6 2.2HP VS, May 2015 install/build, SWG Turbo cell T-9, First choice 3/4 booster, Hayward Pro logic PL-P-4, Polaris 280,Jandy Pro series LED lighting.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Ecopump first electric bill
    That is pretty good! My VS pump tells me how many watts it is using. For skimming and making chlorine it runs at 1100 rpm and draws 150 watts. For the solar panels it runs at 1950 rpm and draws 550 watts. We pay 10 or 11 cents.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I have a single speed 1hp pump. a 1hp pump draws 748 watts for comparison, I see pooldv's VS pump is running at 150 watts. you can easily calculate your cost. my pump runs 5 hours a day and I pay $0.12/kwh. that works out to $0.45 a day. if you are running the VS at 150 watts, but running it for 10 hours a day, that is $0.18 a day, so you can see the cost savings. depends on how many hours your run your pump at what wattage.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I pretty much hate you all. Well, I'm envious of you all. My pump costs about $.21/hr to run. I need to look at 2 speed pumps.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    DFW, TX
    24,502
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I need a bad gateway?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I looked it up. It would take a while to break even on ~$700.
    DFW, TX
    24,502
    Quote Originally Posted by n240sxguy View Post
    That dang link didn't work? works fine here. weird, sorry.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I looked it up. More than I want to spend. I can get an AO Smith/Century 1.5 hp 2 speed for right at $300. There is an advantage manufacturing motor on Amazon for $219. Not sure of the brand quality on that one. At 8 hrs run time it would save me $37/month to switch. Either way it would take til sometime next summer before I break even. Wouldn't be bad to drop a couple hundred and have a chunk drop off my electric bill though.
    Jun 2015
    Temple,Tx
    12
    Yes I think you'd be happier at the end of the day saving money. As far as I can tell Ecopump is worth the cost.
    Now on another subject:Why would anyone install a Gunite pool over fiberglass, except limited size and shape of fiberglass?
    Are there any gunite Vs fiberglass comparo's?
