Results 1 to 8 of 8
Thread: Conversion of ounces
    Jun 2015
    Bloomington, IL
    8
    Pool math says to add 38 oz of Borax to raise pH. Found an online converter that said 5 cups. Is that correct?
    Pooll - 15'x42" Intex Metal Frame above ground pool
    Filter & Pump - Intex Krystal Clear Sand Filter Pump & Saltwater System CG-28679
    Pool Installed - May 30, 2015
    Test Kit - Taylor Technologies K2006
    (Please let me know if there is any other information I should add to my signature.)
    38,521
    Re: Conversion of ounces
    PoolMath tells you both the weight and the volume ... no idea what the converter is telling you.
    Jun 2015
    Bloomington, IL
    8
    How does one go about weighing 38 ounces or measuring 38 ounces of a solid?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Solids and liquids are easy. Measuring cups. You probably ought to get one just for the pool. http://www.target.com/p/oxo-angled-m...d_viewed|pdpv1
    Weight is also easy if you have a kitchen scale. Doesn't anyone diet around your house?
    Jun 2015
    Bloomington, IL
    8
    The box is 76 oz so I added poured in about half of it. Should I have the filter running?
    Richard320's Avatar
    Jan 2010
    19,067
    Quote Originally Posted by rdowns67 View Post
    Always have the filter running when you add chemicals. You want them to disperse as fast as possible. Specifics on how to add different things are in Pool School - Recommended Pool Chemicals
    Jun 2015
    Bloomington, IL
    8
    Thank you richard320!!!
    22,553
    If you hover the mouse over the volume cell it will tell you in standard quantities (gallons, quarts, cups, oz.) how much to add.
