Results 1 to 7 of 7
Thread: Hayward H400 IF, What I did today and it still isn't working.
    Jun 2015
    Manahawkin
    6
    Ok, this may be a bit long but I just want to describe everything. A few days ago the pump motor was leaking that goes into the skimmer basket before the filter and heater. I took the motor off and had all of the seals replaced and I put on new gaskets as well. The heater was working great at this point. I go to fire up the Heater after replacing the pump motor and gaskets and get the IF code. Have had it happen before and just needed to clean the orifices over the years. The pool and heater were installed in 2004 or 2005. So today I pulled the gas manifold off as well as all eight orifices and gave everything a good cleaning. I then took out all burners and cleaned them up with some compressed air. Put everything back to together and am getting the gas sound but no igniter sound. I picked up a new igniter and am now getting the gas "whoosh" and the igniter is clicking. I see flame on the bottom of the unit with the panel removed. Goes off after 4 or 5 seconds, cycles 3 times and throws the IF code. What am I missing? What am I doing wrong?
    Thanks
    Bob
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Hayward H400 IF, What I did today and it still isn't working.
    Which exact model of Hayward do you own, ED, ID, FD?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2015
    Manahawkin
    6
    Model number H400ED2.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Either the soldered contacts on the board where the ignitor is plugged into or the board itself is bad. Seeing you already replaced the ignitor, that would be the next steps to take.
    Paul
    Jun 2015
    Manahawkin
    6
    OK Thanks Paul. How would I know if the soldered contacts or the board itself is the culprit?
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Only way I know is if the module you plug it into wiggles. If no wiggle, then I would say it's soldered good and then you are looking at replacing the board.
    Paul
    Jun 2015
    Manahawkin
    6
    It doesn't wiggle. I guess I have to spring for a board. Thanks again for the help.
    Bob
