Thread: Low salt
    Low salt
    We have had our salt water generator for about 3 years for our 13,000 gallon pool. This year, we put 280lbs of salt in it when we filled it. It registered low salt, so we added 120lbs more. Still low salt. Added another 200lbs. Still low salt. Any ideas? We've never had to add this much salt and still have it say low salt.
    38,475
    Re: Low salt
    A SWG reading low salt is a sign of a dirty or failing cell.
    You really should have used an independent test kit to check the salt level.
    At this point you have now added 600 pounds, which according to PoolMath is 5500ppm of salt ... WAY too high for the typical SWGs and you will now have to replace water when you get your SWG fixed/replaced/running again.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Mar 2015
    New Orleans, LA
    81
    Re: Low salt
    Don't know what kind of system you have but the sensor probably needs replacing.
    May 2013
    Ontario, Canada
    63
    Re: Low salt
    What is your water temperature?
    Don't forget to update your signature.
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Low salt
    That's true, water temp below 65 or so can cause the SWG to report false low salt errors. Update your location so we can see what climate you are in.
