Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: First above ground pool. Make sure I have everything correct.
    Jun 2015
    Houston, TX
    24
    Just got the Intex 18'X48" Ultra Frame Swimming Pool and already have plans to add a through the wall skimmer, fountain and new pump with a saltwater chlorine generator. I have been doing a lot of reading and think I have most of this figure out but would like to make sure.
    For the pump I will be going with this Amazon.com: Intex 120V Krystal Clear Sand Filter Pump Garden
    Will I be okay with the 1500 GPH or do yall recommend the 2150 GPH model? I am thinking the 1500 GPH should be okay.
    I assume this pump comes with 1.5" hoses and new wall fittings. If not and it comes with 1.25" then I will need 4 1-1/4 inch Cantex conduit box adaptors so that I can run 1.5" hard pipe. Or should I get larger wall fittings?
    For the skimmer I plan to go with the Hayward SP1091LX
    through the wall skimmer http://www.amazon.com/gp/product/B002DPY196/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER. Is this meant for 1.5" or 1.25" pipe?
    Now for the plumbing and the fountain. I want to run the the old suction port and skimmer like this
    And the fountain like this but only with a second ball valve between the fountain and return fitting.
    Thank you for the help.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: First above ground pool. Make sure I have everything correct.
    Well, I'm not that versed on the Intex, but just wanted to say Hi!
    Welcome to TFP!!
    Looking at your username, I assume you know my hometown growing up - Jacksonville....
    Support the site
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    The 1500 GPH pump will suffice, but if the difference in price is marginal, get the larger pump. If you ever decide to add a robotic cleaner, you'll be glad you did.
    Also, I would not recommend the pump/SWG combo units, as one or the other will invariably quit first. I suggest a standalone SWG.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Bigger pump separate swg and pump.
    Jun 2015
    Houston, TX
    24
    Which pump is recommended? Can do the SWG later then. Also when upgrading the pump will it come with new through the wall fittings that are 1.5" or only 1.5" hoses?
    Jun 2015
    Houston, TX
    24
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP.
    I have the Intex Krystal Clear sand filter pump and love it. The one you linked is the 2150gph model. I would go with a larger model. I have the 2800gph model. Your pool is larger than mine. I would either go with the one I have or even the 3000 gph model. All are available on Amazon.
    Hoses that come with it are 1.5". I added larger outlet and return holes. Yours may already have the 1.5" since it is a 18' round.
    It does not come with new 1.5" fittings. Just the hoses.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Yes, the 18' should already have 1.5" fittings. My 16' does.
    Pentair IC40 SWG
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by jeffchap View Post
    Good to know for when we upgrade our pool Jeff.
    Lisa
    Jun 2015
    Houston, TX
    24
    Quote Originally Posted by Azgirl71 View Post
    Welcome to TFP.
    That makes things a lot easier. Thank you.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome.
    Lisa
    Jun 2015
    Houston, TX
    24
    Does a water fall really cool a pool significantly?
    Apr 2015
    north west, tennessee
    35
    Great Idea on adding the 2nd valve!
    38,500 gallon |In Ground | Chlorine | Vinyl Liner | Pentair Triton Sand Filter | 1.0hp Magnetek motor | 3/4hp Magnetek poster pump | TF-100XL Test Kit | North West, TN
    Jun 2015
    Houston, TX
    24
    Quote Originally Posted by tim5055 View Post
    Welcome to TFP!!
    Thanks, sorry I missed this in the beginning.
    I am familiar with Jacksonville but never did have to be stationed there or have to train there. I spent most of my time on Oahu.
    Quote Originally Posted by swayne View Post
    Jun 2015
    Houston, TX
    24
    Also in the first picture. The fitting that connects the original hose to the pvc. It looks to be an electrical conduit fitting. Can someone tell me what part this is?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I think it is a electrical bushing. I cannot remember the size.
    Lisa
    Jun 2015
    Houston, TX
    24
    looked for it and couldnt find it on the lowes site. Will just have to take the hose with me. Im guessing the hose has different threads than the standard PVC fittings.
    I think I found it on the homedepot site
    Carlon 1-1/2 in. Non-Metallic Terminal Adapter-E943HR-CTN - The Home Depot
    And now that I have the part number I found it at lowes but it is no longer available
    Shop CARLON 1-1/2-in PVC Adaptor at Lowes.com
    May 2015
    Tampa Bay, FL
    16
    Hi! Also new and have learned a lot. I'm in the same process as you, but with a 16'x48".
    The connector in the first picture is a purpose-made adapter to go from PVC to the Intex hose. Like this:
    http://www.amazon.com/GAME-4560-Conv...887210&sr=1-22
    For the PVC side you would use a Female pipe adapter.
    Coleman 16' x 48" AG, Sandpro 75D 3/4HP Pump/Sand filter, Intex SWG, Hayward SP1091LX Skimmer and 2 Hayward returns, hard piped, K-2006, K-1766 Test kits w/Speedstir and Samplesizer
    Jun 2015
    Houston, TX
    24
    Ok so will the part I linked work? In other words, will it fit the intex 40mm flex tube and threaded connector.
  20. Back To Top    #20
    May 2015
    Tampa Bay, FL
    16
    Here's a white PVC version of what you linked up against the intex hose:
    You can see that the sizes are pretty far off. There is no direct PVC to Intex hose fitting that I know of. You have to use an adapter similar to the one I linked, or build a custom one (do a forum search for "intex adapter")
