Thread: getting ready to get a new pool
    Apr 2015
    Rocky Point, NC
    14
    Well the kids and wife have convinced me to retire our 8 year old 16x48 intex. We are going to go with a 26x52. I have an idea for the new pools placement. I am planning on making a 28x28 square from 4x4 treated. Making sure all sides are level, then fill in with paver sand and compact it with a plate compactor. Will this paver sand make a good enough base for the pool? Just an idea, what say y'all?
    Jul 2014
    Albertville, MN
    21
    Re: getting ready to get a new pool
    I used a fine sand in the bottom of my 24' Radiant but do have several wrinkles. I'm not sure what else you'd use.
    Semi Above-Ground - Radiant Metric (24')
    Hayward H150FDN Universal H-Series Low Nox 150,000-BTU Natural Gas Pool Heater
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    That's exactly what I did, just on a larger scale: Dimension at the ground for Intex 16' Ultra frame pool.
    Most people here will advise against the use of sand, but mines been up going on 4 years now with no problems (once I finally got it level!).
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    We are in the process of upgrading from an 18' to the 26'. We are moving it to a sunnier location, on the edge of a field. We decided to out 5 ton of modified 2A rock something or other, ha, down before the sand. My husband is going to tamp it down as soon as this rainy spell is over. I Also got a pad, similar to a Gorilla pad, to put down. Along with some concrete pavers under the posts. Hoping to have the pool for a long time!
    Keep in mind, the sand washes away more easily than rocks or undisturbed dirt.
    Apr 2015
    Rocky Point, NC
    14
    Thanks for the responses. I don't think wash out will be an issue as the sand will be in the frame. Would crush and run work better than sand?
    Casey's Avatar
    SW PA
    10,438
    Crush would be a lot better.
