Thread: When can I add sequestrant ?
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    TA is at 180. CYA is at 35, PH is 75
    I was told that the TA and PH and chlorine need to be low in order for the sequestrant to work. Is this true?
    Thanks
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: When can I add sequestrant ?
    If the chlorine is too high, it will oxidize the sequestrant too quickly and will also oxidize ferrous iron to insoluble ferric. If the pH is higher, then the metal ions will precipitate or stain as metal oxides-hydroxides. Usually a higher TA level results in the pH rising over time, but by itself I don't see it interfering with the metal sequestrant (I presume you are trying to remove iron or copper and not calcium carbonate scale).
    So the usual sequence is to first get the chlorine to near zero and the pH low and use a stain remover such as ascorbic acid for iron stains or citric acid for copper stains. Then one adds a metal sequestrant product and slowly raises the chlorine and pH to normal levels. One continues to add metal sequestrant product at a maintenance dose each week to replenish that lost by oxidation from chlorine. Metal sequestrants that use HEDP are more resistant to such chlorine oxidation (compared to, say, EDTA), but nevertheless they still get broken down.
    The other approach to removing metal from the water is to do a water replacement after the stain is removed (i.e. after the ascorbic acid or citric acid treatment).
    Yet another approach to removing metal from the water is to use CuLator, but if that is done and isn't working for any reason then the company needs to be contacted for special procedures. CuLator is not inexpensive, but if water replacement or ongoing metal sequestrant use is expensive or cumbersome then it's an option.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    +1 on Chemgeek's explanation...^just to add that each Mfg of the two recommended sequestrants has slightly different instructions. Metal Magic wants your ph to be above 7.5 when you use it, and prefers FC to be in the 1-3 range.
    Jack's Magic Pink prefers ph of 7.2.
    Your parameters will depend on which you purchase...once you buy your metal sequestrant, just follow the directions
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2013
    Cedar Lake,IN
    58
    Thank you
