Thread: Deck around Above Ground Pool
    May 2015
    Fort McMurray, Alberta, Canada
    50
    Hi Folks,
    I have an above ground pool with decking about 1/4 way around, I am looking to build the deck around the pool. Is there anything I should look out for with regards to leaving access to the pool in the even of issues in the future. For example if the liner needs to be replaced will the deck surrounding the pool cause issues with this?
    Thanks.
    33' x 18' x 4' Oval Above Ground Pool (~15700 Gallon)
    Jacuzzi 15LRC-5-S1 1.5 HP Pump
    Sta-Rite T210WF Hi-Rate Sand Filter
    Hayward H400FDN Heater
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: Deck around Above Ground Pool
    Make sure you can get to and work on your equipment. That includes being able to remove it if needed. As far as the liner I am not sure. If your deck goes over the edge of the pool then I would think it would make it hard to remove and replace the liner.
    Kim
