pool opening / slam ph high?
PH is actually supposed to be at 7.2-7.5 before starting the SLAM. At this point, continue with the SLAM (thoroughly) by maintaining it until you pass all 3 criteria. Don't let that FC SLAM level drop. Once the SLAM is done, then you can go back and adjust the PH.
The 3 SLAM objectives are:
1. Water is clear
2. You do not lose any more than 1ppm of FC overnight (that's the OCLT)
3. CC (Combined Chlorine) is <.5
I would slightly disagree with Pat.
The pH test is not valid when FC > 10ppm.
If the FC drops below 10ppm, test the pH and get it into the lower 7s before raising the FC level back to for the ShockLevelAndMAINTAIN Process.
What test kit are you using?
Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
