I have been battling cloudy water since I opened the pool 4 weeks ago. The few times I have seen the bottom, it had a powdery substance in it. As soon as I get near it with the vacuum, it goes into the water as a cloud. I have been vacuuming to waste the few times I could see the bottom.
In the last week, I upgraded my pump from a 1/4 hp intex sand filter to a 1 hp pump with a hayward sand filter.
What else can I do? I have been trying to keep the chlorine high to kill off any algae in case that is why it is cloudy. Last time I added liquid chlorine was 12 hrs ago. Over the past 4 weeks, I have added 2 boxes of borax to see if maybe the low pH might be causing problems. I used the pool calculator.
TC 6.1
FC 5.7
CYA 26
Total alkalinity 47
pH 7.1
Thank you!
Intex ultra frame14ft across 42 inches deep.
TC 6.1
FC 5.7
CYA 26
Total alkalinity 47
pH 7.1
Thank you!
