Results 1 to 10 of 10
Thread: Cloudy water - frustrated.
    Apr 2014
    Graham, Tx
    7
    I have been battling cloudy water since I opened the pool 4 weeks ago. The few times I have seen the bottom, it had a powdery substance in it. As soon as I get near it with the vacuum, it goes into the water as a cloud. I have been vacuuming to waste the few times I could see the bottom.
    In the last week, I upgraded my pump from a 1/4 hp intex sand filter to a 1 hp pump with a hayward sand filter.
    What else can I do? I have been trying to keep the chlorine high to kill off any algae in case that is why it is cloudy. Last time I added liquid chlorine was 12 hrs ago. Over the past 4 weeks, I have added 2 boxes of borax to see if maybe the low pH might be causing problems. I used the pool calculator.
    TC 6.1
    FC 5.7
    CYA 26
    Total alkalinity 47
    pH 7.1
    Thank you!
    Intex ultra frame14ft across 42 inches deep.
    38,292
    Re: Cloudy water - frustrated.
    Welcome back ... look like you posted a question last year and then we never heard from you again
    What test kit are you using?
    Are you trying to follow the ShockLevelAndMAINTAIN Process?
    What kind of filter do you have? Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Apr 2014
    Graham, Tx
    7
    Thank you. I think I added all the info. I have test kit that does not test free chlorine. I took water to the pool store to get these results. I have ordered a tf-100 test kit.
    14 ft intex ultra frame above ground, 1 hp hayward pump with 18 in sand filter
    38,292
    Good call on the TF-100 ... it is going to be hard to make any suggestion until you can provide those good test results.
    In the meantime, have you ever Deep Cleaned your Sand Filter to make sure it is ready to clear up the cloudiness?
    Jun 2014
    15,145
    Best thing you could've done! You will love the kit, and it will make your pool care much more accurate and efficient.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Welcome back!
    You'll have that test kit in a few days and things will accelerate, especially now with that new upgraded sand filter. I predict you'll be kicking yourself that you didn't buy the kit last year when you see how crystal clear your pool will become and how easy it is to maintain once you're in control. Go ahead and start sending out invitations to Fourth of July at your house. You'll want to show off your pool.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    A good test kit and a little diligence and you will own a sparkling clear pool from here on.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Apr 2014
    Graham, Tx
    7
    Thank you all. I will be back when the kit arrives.
    Apr 2014
    Graham, Tx
    7
    I ended up buying hth clarifier. I added 1 oz and by morning my pool was crystal clear.
    I got my tf100 test kit today.
    FC 7
    CC 0
    Calcium hardness 400
    TA 50
    pH 6.8
    CYA 50
    It looks like I need to raise my pH and total alkalinity. I read to aerate to increase TA with a low pH. What is a good way to do this or should I add the recomended amount of baking soda?
    Do I correct pH with borax first before I try to correct the pH?
    Thank you.
    38,292
    Aerating raises pH not TA.
    I would raise the pH with borax or washing soda into the 7s and then see if you need to bump the TA with baking soda.
    You should also raise the FC level to shock level and Perform the Overnight Chlorine Loss Test because cloudy water usually means there is something lurking ... and clarifier will not kill it. If you fail, then you need to follow the ShockLevelAndMAINTAIN Process.
