Thread: iAqualink temp calibration?
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    so it's finally heating up a bit in Southern California. My iAqualink app reports that my pool is 83.....BUT my heater says the pool is 81. I believe the heater since you can really feel the difference. I had a party a couple weeks ago and heated to 80 via aqua link, and it felt chilly, now I know why. Is there a way tio get these two to cooperate and agree on a temperature?
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: iAqualink temp calibration?
    On my Pentair system, you can calibrate the controller temp to the heater temp showing. That's what you are supposed to do on mine.
    Essential Links:
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    I think you have a calibrate function on the iAquaLink. Go to MENU>SYSTEM SETUP>TEMP CALIBRATE. This should allow you to calibrate +/- 4 degrees.
    -25,000 gal. freeform gunite, smooth quartz finish w/ spa
    -2 hp Jandy Pro Series Stealth; Jandy Pro Series Cartridge Filter (CV340)
    -Jandy Pro Series AquaPure Chlorinator; Jandy Pro Series JXi Heater
    -Zodiac MX8 cleaner; Taylor K-2005 DPD Complete Chlorine Kit
