Thread: Coping repair - quik-crete OK?
    https://docs.google.com/file/d/0B-V_...p=docslist_api
    Can I just slap this piece back in place with some quik-crete and be done with it or am I asking for trouble?
    Thanks in advance!
    Gina
    15,500 gal, IG, plaster, DE Nautilus NS36, Pentair WhisperFlo pump 2-speed 1.5 HP, 1993
    Jun 2012
    western NY
    1,560
    Re: Coping repair - quik-crete OK?
    You will need to chisel out any old mortar. In order to put a new mortar bed down to work properly the old needs to come out to make room. It has been a long time since I did any brick work but, I think Type S mortar will work in this situation. A good solid, Clean and dry surface on both parts is needed.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Thanks. Put it together last night. It seems like it will be fine. No more swimming hazard in the deep end.
    Gina
