Results 1 to 14 of 14
Thread: My head is 'swimming' with decisions about new PB!
    Jun 2015
    Goodyear, AZ
    4
    Hi all!
    It is time for hubby and I to decide and my head hurts from all the info. We had 5 PB's come out- 1 never got back to me, so down to 4...Caribbean, Thunderbird, Shasta and California. Our budget 28k, so we have limitations! The later 2 have quotes over 31K, so we politely declined (it really was a very simple pool we want).
    We have a small yard, so it is basically a play pool. Perimeter: 75 and Depth: 3.5x5. No water features.
    We are deciding between the in floor system (3k expense) or a robot. If we get a robot we may add the water feature back in (aesthetic vs. function). I have 2 teen age sons, so we have manual labor to help clean the pool!
    Your opinions on water feature (cascade coming through a wall on back of pool) or in floors??
    We have a small berm in the back of the yard so that is a concern. 2/4 companies feel like we need a small wall to block the dirt from going into the pool. (hence why the water feature is on the table)
    Pebble- tec or sheen, I cannot get a clear answer on which is better.
    I am so confused about the in floor and how serious an issue the berm is!
    I feel like everytime I talk to one of the 2 favorites, it gets more confusing. Now one company is recommending a geometric pool (originally it was free form), but the hubby does not like the rectangle shape.
    Finally my last issue is acrylic decking cost. For 343 sq foot of exiting patio, I have a quote for $1.2k to add the lace and a quote for $2.3k.
    Any solid advice will be appreciated.
    Mar 2015
    peoria, az
    57
    Re: My head is 'swimming' with decisions about new PB!
    Don't let PB tell you what kind of pool you want, its your pool. If i told a PB I want freeform and they kept saying square, I would have walked away.
    Tec vs Sheen. Both good products and same for durability, Sheen is smoother, peblletec has bigger pebbles.
    For your deck, did they give you a break down of the cost per square footage? Make sure your quotes are broken down line item so you can see exactly what is going in and the cost involved.
    (Started 4/20/15) 32' x 16' In-ground Presidential Pools(3-5-4) 14K gallon salt water pool, Pebble Radiance Kona Blue, Pentair Inteiliflo pump, 420 Cartridge filter, Q-360 in-floor cleaning, Eclipse drain, 2 Spectrum 360 LED lights, Grotto w/waterfall, Trazocrete table with bench seating, 2 deck jets, Baja step, 400 sq ft acrylic lace deck - Sonoran Stone.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I would have to see the berm to comment on it. I can tell ya though, a friend of mine has a large berm by her pool, and its horrendous.
    If you did put a wall there, you would need to put a lot of gravel behind it so the water would drain out from behind the wall. if you dont, it will just overflow the top.
    My vote is for the robot cleaner and scratch the in-floor system .
    Divin Dave,
    TsTime's Avatar
    Jun 2015
    San Diego CA
    16
    I am right with you, we too are in design and bid process and getting a clearer picture thanks to this forum. Hang in there, the end result will be worth it.
    In design and proposal stage: 46'x10' - 2ea 2'x10' 8" & 12" deep Baja Steps - 4-7' Deep - 2 Sheer Descents - 15,000 gallon in ground - Automatic Cover (under coping)- SWG - 400,000BTU NG Heater - Unknown size/brand pump(s), filter, LED, cleaner type and pool finish
    Jun 2015
    Goodyear, AZ
    4
    Thanks for the replies. Just getting my thoughts down helped.
    The berm is about a foot, not too big. It is funny, since I posted I asked one PB for a quote on a water feature and he emailed back 'look on our website'. Hmmm, if he is not too interested at this stage, I wonder what it will be like after we sign.
    I am leaning toward the robot, I think we will get more enjoyment from the water cascade.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Take all the time you need. Maybe you have a reason to rush, but probably in the long haul, you can take your time. I NEED my pool for physical therapy, and I'm choosing to go slowly. It's such a huge investment. So read and read the forums and google the rest of the internet, too. And if you aren't sure of a decision, just keep thinking and researching until you are sure. I wish I had found this site a year ago. I can't wait for our pool, but I definitely would have done some things differently. There's just so much to learn, because many things about a pool are permanent (or at least fixed for many years).
    My vote is also for the robot, especially since your pool is smaller and you have two sons to help!!! When the boys leave, you can always upgrade to remote control. I hear that's fun!
    We're going with Pebble Sheen. We like the feel of the smaller pebbles. I'd prefer no pebbles, but for the warranty and durability, I think the pebbles will be worth it. In our Houston area, Pebble Tec is a sharp upgrade; another no-brainer for us. Some people like the look of the larger pebbles with the Pebble Tec. I don't care one way or the other on that.
    Water feature: I think it's nice. You can use it when you want to add a little glitz and sound to your pool. I love having water splash down on me on a hot, hot summer day - when I'm already in a pool!! LOL!!
    Sorry, but I'm too inexperienced to help with the berm and deck issues. But there are plenty of great people here who will add to the information. Congratulations on deciding to have a pool! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    Pebble Sheen is much smoother with finer pebbles, but both are of equal quality. Over and over we hear about problems with In floor cleaners. I second the Robot.
    Essential Links:
    TW Pool's Avatar
    Mar 2015
    The Woodlands, Texas
    79
    Nellie, not to take up for PB's (I decided to build my own), but you are kind of in peak season right now. Having gone through most of the steps, I have to think most PB's don't want to spend a ton of time on a low dollar pool. The flip side to your thinking might be the ones that are responding aren't as busy (which makes you wonder why).
    I also vote robot.
    New DIY IG pool in Houston, Texas. 4/30 dig to 6/11 fill. 20' x 42.5' free form pool/raised spa with the following equipment: 3hp Intelliflow pump shared between pool/spa, 120gpm Pentair Waterfall pump, 6' sheer decent, 2 bubblers, 2 large color LEDs in the pool/1 small in the spa, Easytouch 8 with ScreenLogic2, Stenner Pump, auto fill, a 2HP silencer pump for the spa, 850 sq. ft Sundeck, Dolphin Supreme M500 and a TF100+mixer
    Jun 2015
    Goodyear, AZ
    4
    Fair point, TW Pool. I had most of the builders come out in March, with the understanding that the build would be later (I was up point about the timeline). But yes, I hear what you are saying!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Take a pic of the yard and see if you can spray paint the "pool" on it.
    We LOVE to help people spend their money!
    Kim
    JoyfulNoise's Avatar
    May 2015
    13,210
    I vote robot or an extra port/line for suction/pressure side cleaner. I think the in-floors on such a simple pool is overkill.
    Try to get as much automation as your budget will allow as that helps a lot with ease of use. There's only one valve in my entire setup I have to manually turn on any regular basis and I'm seriously thinking about automating it.
    Water features - keep it simple. We have an complicated waterfall with little pools of water in it for extra splashy sounds. I hate it because it's a maintenance nightmare (algae breeding ponds is what I call them!). If you do a sheet descent, keep in mind the stone texture and design as it will develop calcium scale over time. Dark stone shows the grey-white calcium scale much sooner.
    Berm - like others said, a picture is worth a thousand words. Sounds like it does need a retaining wall so I think the PBs are on target with that.
    I have PebbleTek. Friend has PebbleSheen. Honestly I like both.
    Not sure what other equipment you're getting but get the biggest filter you can. I'd go cartridge and go big. Then those strapping young teenagers only have to clean it once or twice a season
    Matt
    Jul 2012
    Tallahassee, FL
    30,525
    How bad is it when I see a waterfall or sheer decent all I can think of is how hard it would be to keep clean?
    Kim
    May 2015
    13,210
    Quote Originally Posted by kimkats View Post
    Kim
    Actually, my spillway and waterfall (and pool tile) got really bad one winter because I got lazy and let the water go for too long without proper testing. The CSI went way over +0.6 and, over the course if the winter, I developed calcium scale all over everything. I then paid for that mistake by paying for a tile cleaning service to come out and soda blast everything clean (kieserite or magnesium sulfate blasting). Worked beautifully to clean all the calcium but set me back ~$300 ($3 per linear ft of pool perimeter).
    The last few years, I have kept my CSI carefully in check and I have developed little to no scale. Anything that has developed is easily acid washed away with a dilute spray of muriatic acid.
    So water features can be very beautiful but they do require care and maintenance to keep them that way.
    Matt
    Jul 2012
    Tallahassee, FL
    30,525
    Another example of live and learn!
    Kim
