Results 1 to 15 of 15
Thread: Waterfall
    Jun 2015
    Spring Hill, KS
    5
    Waterfall
    Hello,
    We have an in-ground pool that has a waterfall with a 1.5 HP pump. Recently, we noticed that when the waterfall is turned on, the regular pool pump is not sucking in water through the main drain and skimmers. But when we turn off the valve to the waterfall, the main drain and skimmers work great. Does anyone know what would cause the main drain and skimmers to not function correctly when the waterfall is on? I suppose an easy option would be to turn off the main pump while the waterfall is on so it doesn't burn up the pump, but I'd prefer to figure out why it's doing what it's doing.
    Thanks!
    Waterfall
    Jun 2014
    15,253
    Re: Waterfall
    Welcome to TFP! . So to be clear ... based on what you are saying .. if the waterfall is on, you get NO suction which means their is probably no prime (water) to your pump - no water flowing back through the suction side? Is that correct?
    Might also help the readers to know all the other pieces of equipment you have on your pool to give you the best advice. Be as specific as possible please.
    Jun 2015
    Spring Hill, KS
    5
    Re: Waterfall
    Thank you! This looks to be a very helpful site and as a new pool owner, I'm looking forward to using it as a good resource!
    That's correct, when the waterfall is on, the main pump is not pulling water in from the pool. We have 4 pipes total coming from the pool into the pump area - 1 for the waterfall, 1 for the main drain, and 2 skimmers. The pipe for the waterfall ties into the pipe for the main drain right by the pumps so my hunch (although I am by no means an expert) is when the waterfall is on, perhaps that is reducing the vacuum effect that the main pump would otherwise produce and therefore the main pump does not have enough juice to suck the water through the pipes to the pump and through the filter. But that's just a guess.
    Waterfall
    Jun 2014
    15,253
    Re: Waterfall
    See, that's different from mine, and personally has me stumped, so others will answer as well I'm sure. In my pool, the waterfall comes from the pressure (return) side after the filter - just like the jets. So I have a 3-way valve to adjust whether I want 1) All waterfall, 2) all return jets, or 3) combination. But in your case you are describing the waterfall pulling water "before" it gets to the pump which seems odd to me. I will be curious to monitor this thread as well to see what other ideas our TFP'ers may have.
    Jun 2015
    Spring Hill, KS
    5
    Re: Waterfall
    I'll take any help I can get! And just to further clarify, we have two separate pumps. There is a dedicated pump just for waterfall and another (older) pump where the main drain and skimmers tie in to and that main pump goes to the sand filter, etc., etc. I'm not for sure on the older pump, but I'm pretty sure it's a 1.5 HP as well (they're both about the same size). Something else I was wondering is if it would work to disconnect that line from the waterfall pipe to the main drain pipe, in essence making the waterfall on its own loop?
    Waterfall
    Jun 2014
    15,253
    Re: Waterfall
    I'm sure some of our plumbing experts will have an idea or two. Personally I'm stumped, so I'm very curious to see what comments you get. Sorry I personally could not help in this case, but welcome again to TFP. I think overall you'll be pleased at the wealth of knowledge you find here.
    Jun 2014
    15,253
    Re: Waterfall
    We haven't forgotten about you. Check back periodically because someone will have an idea or two for your waterfall/pump water flow issue.
    38,521
    Re: Waterfall
    Welcome to TFP!!!
    I am a little unclear about your plumbing setup so adding a drawing or some pictures might help.
    From what I understand of your description, there is no reason that the main pump should not be moving water when the waterfall is on.
    JoyfulNoise's Avatar
    May 2015
    13,253
    Waterfall
    You're problem is you have two pumps drawing on the same pipe. The waterfall pump is essentially hooked up to the main drain and the pool pump is hooked up to the MD as well.
    Whoever did the plumbing job wasn't thinking straight or should have added a valve so that the MD feeds only one pump at a time. Otherwise the pump with more HP and lower head loss on the suction side will win.
    Can you post a picture? I'm really having a hard time believing the plumber was that dumb.
    FYI - I have a waterfall with totally separate plumbing (waterfall pump, wall drain and two returns) to avoid causing any problems with the pool pump.
    Matt
    Jun 2014
    15,253
    Re: Waterfall
    Thanks everyone for chiming in. I was at a loss on that one as well. Wish I could use some x-ray vision to see how those pipes are routed.
    Jun 2015
    Spring Hill, KS
    5
    Re: Waterfall
    I have attached a couple pictures. On the one close-up picture with the pipes, from left to right, they are the waterfall (currently closed), main drain, and both skimmers. So you can see that they're all kind of tied in together. And then the pump on the top left is for the waterfall and the older pump on the top right is for the main drain and skimmers. Hope this helps and I appreciate all the input!
    Waterfall
    May 2015
    13,253
    Waterfall
    Your waterfall pump and pool pump look to be the same size, are they?
    You should not have both the waterfall valve and the pool pump main drain valve open at the same time. If one is open, then the other should be closed. Basically, two water pumps really should not draw from the same supply pipe.
    What you're seeing is that, when both valves are open, the waterfall pump is basically siphoning all the water away from the suction side of the pool pump. That is why there is little water coming out of the pool returns.
    Matt
    Jun 2015
    Spring Hill, KS
    5
    Re: Waterfall
    Awesome - thank you all very much for the input! I'll just plan to only keep one pump running at a time - that's a pretty easy option.
    Waterfall
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Waterfall
    from the picture it looks like you can run both at the same time but you would have to:
    Close the valve from the main drain to your filter pump
    open valve from main drain to your waterfall
    You waterfall will pull from the main drain and you filter pump will pull from your skimmers, you could leave it this way all the time unless you wanted to pull water from the main drain to waste. I would say 60 to 70% of pools today do not have main drain's and they work just fine
    38,521
    Re: Waterfall
    Cowboycasey has it exactly right. I would just leave the main drain closed for the pool pump.
