Results 1 to 7 of 7
Thread: QBall
    Jun 2015
    Hockley, TX
    2
    QBall
    Hey Gang,
    Found y'all while searching for info on pool maintenance. My wife came home from Wally World the other day and said "I got the kids something but you have to put it together". I look in the back of the Tahoe and find a Coleman 16' x 48" pool. I seem to remember a discussion where we talked about getting a cheaper pool. Apparently, we have differing definitions of "cheap".
    I got the pool set up and filled yesterday, and realized that I'll need to implement a treatment plan. We live in the country and are on well water. I have the TF-100 kit in my cart, but was curious what I should add with that to get the free shipping since I only need to spend a few more bucks.
    Anyway, glad I found this place, and I appreciate the help.
    Thanks in advance...Q
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: QBall
    Welcome to TFP!
    I would add a speedstir if you're asking me. Good to have you aboard, and enjoy the forum.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: QBall
    Welcome!
    The XL option will do it. That is the one reagent that is virtually impossible to find in stock locally anywhere. The others are easy if you suddenly run out.
    And nobody who has a speedstir regrets it. Ask for it for Father's Day.
    Jun 2014
    14,981
    Re: QBall
    I like what someone said earlier in a post from Breaking Bad .... "With the speed stir, you will be the Heisenberg of pool maintenance".
    Jun 2015
    Hockley, TX
    2
    Re: QBall
    Jun 2014
    14,981
    Re: QBall
    Looks like they had the hard part of the pool installation.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: QBall
    Welcome to TFP! A few resources to give you an overview of our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
