Thread: Hayward heater
    Jun 2015
    Minooka, IL
    1
    Hayward heater
    I have a newly installed, brand new Hayward heater H250FDN. Blower kicks on, burner ignites, then goes out after a few seconds. Tries again, and the same thing happens. It did run once for about 30 seconds. What do I check? After a couple tries, I get the error code IF.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Hayward heater
    IF is an ignition failure. You have natural gas right? Did you have a gas pool heater before this one attached and running at some point? Just checking to see if this is a new run of gas line and if so the length from meter to heater and pipe diameter.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
