Thread: Going in vacation for 20 days
    Apr 2015
    Las Vegas, Nevada
    25
    Hi all,
    I am going in vacation for 20 days and I have some questions regarding the pool.
    I have SWG and it works awesome. I also have rising PH as you can tell. I have no one that I can trust to mesure the PH and adding acid every other day
    I don't want to het the PH crazy high and damage the cell. I was thinking of turning it off and put chlorine pucks in a float and have someone just add pucks every few days. My FC is 7, CYA is 70 and PH as of today is 7.6 /was 7.5 yesterday/.
    So is it a good idea described above or there is something better I can do?
    Thanks
    12000 gallons inground pool with spa, Pentair VS pump, Easytouch 4, Intellichlor 40, Pentair Clean & Clear CC420 cartridge filter, solar panels, TF-100
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Going in vacation for 20 days
    how high will your pH go?? are your jets disturbing the surface? if so, I would aim them all down to minimize surface agitation. you cant have someone go and add a pre-determined about of acid a few times?
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Apr 2015
    Las Vegas, Nevada
    25
    Jets are turned down but have spillway from the spa to keep water balance 2 hours a day
    The PH goes above the max on the test kit in just few days
