Results 1 to 8 of 8
Thread: Aqualink RS6 Pool/Spa Control Button Turning On Randomly
    akhil's Avatar
    Jun 2015
    Irving, Texas
    37
    Hi- I have Aqualink RS6 Pool/Spa Control. I just moved 2 weeks back and don't know much about the pool/spa control.
    Since last week I am having issue with Spa light turning on automatically. It is very sporadic and spa light turn's on at any time. Also yesterday my filter turn on in the night (even tough it is set during day time).
    Can someone please help with why button's are turning on at random time?
    Akhil
    Year built: 2000, 16,000 Gallon, In Ground Pebble pool- 90' perimeter/19'*35'(W*L), Pentair Pool filter, 200 sq.ft. cartridge filter, Jandy energy filter, Polaris 360 pool Cleaner, Clear Vision natural water purifier : Model XG, Century centurion pump motor (HP 2.0, Hz: 60, Type: CX), Jandy valve (JVA 2440), Pool heating- Delta family (120V, 60Hz, 3 amps), Aqualink RS6 pool/spa control
    Jun 2015
    Wildomar, California
    423
    Re: Aqualink RS6 Pool/Spa Control Button Turning On Randomly
    Hi AK. Does your spa have a remote in the spa? If it does, that's the problem. Either moisture has gotten into the switch or it is shorting out due to wire damage. Either one of these 2 scenarios will cause any of the 4 programmed buttens to turn randomly turn on and off. It's strange, but can be costly if it turns the heater on!
    akhil's Avatar
    Jun 2015
    Irving, Texas
    37
    Thanks for your reply. There is no remote. Do you know what can I do to fix it? Today the air filter and spa are turning on in every 30 minutes
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    If you have no remote at all connected, then it sounds like the PCB board is having issues. A possible replacement is in your future more than likely. Have you tried a power reset on the system? You checked the programming to make sure it's still accurate?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    akhil's Avatar
    Jun 2015
    Irving, Texas
    37
    Thanks. Programming is correct as I didn't changed it. I will try resetting it but I do not see any option for power reset. Can you please suggest any power eset with Aqualink RS6?
    akhil's Avatar
    Jun 2015
    Irving, Texas
    37
    Just figured out that here is a white color 4 button remote. Can someone tell me how can I unplug connector from the board?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You should be able to disable through the control panel:
    wake up unit.
    push down arrow to highlight "menu", push select.
    scroll to "lockouts", select.
    scroll to "spa switch", select.
    scroll to "lock", select.
    Factory Warranty Station for:
    Nov 2016
    Houston TX
    1
    Did anyone figure out a fix? I have this same system and the system is randomly turning the heater and filter on in the middle of the night. Also, I try and manually turn the heater on at the heater and it says there is a ignition failure on my LXI heater.
