Results 1 to 11 of 11
Thread: Aqua Trol Grounding
    May 2015
    Pittsburgh/Pennsylvania
    27
    Aqua Trol Grounding
    Installing a new Aqua Trol and the instructions state to connect the green ground terminal to the ground in the service panel. Isn't the SWG already grounded to the panel through the 3 prong plug and GFCI?
    21' 54" round AGP, Hayward 1hp 2 speed pump, Hayward Aqua Trol HP SWG, Hayward 150 sq ft cartridge filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Re: Aqua Trol Grounding
    Not sure the exact model you have , but this is what I see in the manual I pulled up:
    Input Power
    Models with the standard 120 VAC line cord should be plugged into a GFCI recep-
    tacle. Twist lock models should be plugged into a twist lock receptacle wired to a
    GFCI circuit breaker.
    Bonding
    A lug used for bonding is attached to the bottom of the Aqua Trol enclosure.
    Connect to the pool bonding system using minimum 8AWG copper wire if required
    by code
    What exact model?
    Support the site
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Where did you see that? I didn't see it skimming the manual. The options I saw either had a straight blade plug or a twist lock. Either one should have all the necessary connections done inside the box.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2015
    27
    I have the hp model straight blade plug. Here is a copy and paste from the manual:
    A green colored terminal marked "Earth Ground" is located inside the wiring compartment. To reduce the risk of electric shock, this terminal must be con- nected to the grounding means provided in the elec- tric supply service panel with a continuous copper wire equivalent in size to the circuit conductors supplying the equipment.
    May 2014
    Franklin, NC
    9,198
    Quote Originally Posted by bighendy View Post
    A green colored terminal marked "Earth Ground" is located inside the wiring compartment. To reduce the risk of electric shock, this terminal must be connected to the grounding means provided in the electric supply service panel with a continuous copper wire equivalent in size to the circuit conductors supplying the equipment.
    Found it. Funny, it's up front in the Safety Instructions, not in the section on wiring. But it's there, so it looks like you need to run an additional #12 green wire to the panel ground in addition to the bonding wire you should add to the bonding grid. Do not confuse or interconnect the bond & ground systems.
    Support the site
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    So they want a ground for the circuitry, a bonding wire, and a ground for the case of the unit. Sounds like it would be cleaner looking to just run flexible conduit in place of the cord they supply. Then you could eliminate one of the grounds. Just pigtail the circuitry ground off the case ground in the box. Still have to have the bonding wire.
    May 2015
    27
    I agree not very clean to have a green wire coming out of the case. I assumed it was the same as a 3 prong pump and just grounded through the GFCI.
    May 2015
    27
    I just opened up my unit and the green terminal they are talking about is already connected to the green wire from the power cord as well as the green wire for the 115v outlet on the bottom of the box. If I knew how to add a pic I would lol
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    And there's the problem with having one instruction manual cover multiple products. They probably copied that page from the aquarite and didn't think about changing it to reflect the Aqua trol.
    May 2015
    27
    Yep haha. Definitely no need to double ground the same terminal lol
    May 2014
    Franklin, NC
    9,198
    Cut & Paste is a wonderful thing, but it can bite you in the rear end.......
    Support the site
